MP Orange box to MSD 5 , worth the upgrade?
#734905
06/27/10 04:54 PM
06/27/10 04:54 PM
Posts: 1,018 Hazlet, NJ
440Satellite
super gas
super gas
Hazlet, NJ
I have a Mopar Performance orange ignition box on my 72 Duster 318, I also found an older MSD 5 box that I pulled off my last car in favor of a 6 AL. Whats better a MP orange or MSD 5, is it worth swapping to the MSD 5 box over the orange box?
Its basically a stock bottom end 318 with Edelbrock Performer cam and intake, Holley 650, headers, MSD coil, and MP electronic ignition upgrade, hooked to a 4 spped and 3:91's.
I know the MSD 5 box is the low end, thats why I'm asking, down the road I'll probably pick up a better one.
Butch
1972 Duster
318 4 speed
1958 392 Hemi engine
waiting to be built!!!!!
Re: MP Orange box to MSD 5 , worth the upgrade?
[Re: 440Satellite]
#734907
06/27/10 05:31 PM
06/27/10 05:31 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Kind of funny I see this post as I did exactly the same thing with the same model car 31 years ago....but to answer the question..I swapped the orange box for the MSD 5 and did not gain anything.And for a street car,I doubt you'd gain anything going to the MSD 6 either.
[Re: 440Satellite]
#734908
06/27/10 07:10 PM
06/27/10 07:10 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If it is relatively stock and has no issues with the spark plugs fouling you will not see much of an improvement.
If you the motor tends to run rich because of a cam or carburation issue the MSD will keep the spark plugs cleaner and it will tend not to load up as easily.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: MoparforLife]
#734910
06/27/10 10:59 PM
06/27/10 10:59 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I went the other way when my MSD 5C was starting to fail.
Not even a 5C, to a NAPA chrome box special. No change.
