Re: transmission mount----solid or poly
[Re: joshking440]
#734704
06/27/10 12:33 PM
06/27/10 12:33 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I would use a Poly mount if for no other reason then I heard using a solid could cuase the tail shaft housing to break.
Post deleted by Defbob
[Re: n20mstr]
#734707
06/27/10 06:54 PM
06/27/10 06:54 PM
#734708
06/27/10 09:15 PM
06/27/10 09:15 PM
#734709
06/27/10 09:20 PM
06/27/10 09:20 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have a full tube chassis it has motor plate,mid plate and solid trans mount and have had 0 problems the key to running a solid trans mount is no chassis flex.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#734710
06/27/10 11:17 PM
06/27/10 11:17 PM
[Re: sg66mopar]
#734713
06/28/10 11:31 AM
06/28/10 11:31 AM
WILD BILL
BROOK PARK, OH
Had a rubber mount for 20 years. Now with the B1 power I've broken two belhousings in under 50 passes. Went to a solid mount last week. We'll see what happens.
Mid plate ?
