transmission mount----solid or poly #734703
06/27/10 12:29 PM
06/27/10 12:29 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
Im running a motor plate, passenger motor mount to control fore and aft movement, and possibly a mid plate... so whats the best for the trans
Do I go solid, or poly/rubber mount
Motor makes 1300hp and 1100ftlbs
Re: transmission mount----solid or poly [Re: joshking440] #734704
06/27/10 12:33 PM
06/27/10 12:33 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I would use a Poly mount if for no other reason then I heard using a solid could cuase the tail shaft housing to break.
Re: transmission mount----solid or poly [Re: WILD BILL] #734705
06/27/10 02:46 PM
06/27/10 02:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
heard the same story.
Re: transmission mount----solid or poly [Re: rebel] #734706
06/27/10 03:17 PM
06/27/10 03:17 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
cheap parts store rubber one is all you need
....BAD A$$ STREET CAR.....
Post deleted by Defbob [Re: n20mstr] #734707
06/27/10 06:54 PM
06/27/10 06:54 PM
Post deleted by Defbob #734708
06/27/10 09:15 PM
06/27/10 09:15 PM
Re: transmission mount----solid or poly #734709
06/27/10 09:20 PM
06/27/10 09:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have a full tube chassis it has motor plate,mid plate and solid trans mount and have had 0 problems the key to running a solid trans mount is no chassis flex.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Post deleted by Defbob [Re: dusturbd340W5] #734710
06/27/10 11:17 PM
06/27/10 11:17 PM
Re: transmission mount----solid or poly #734711
06/28/10 12:15 AM
06/28/10 12:15 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Solid motor, rubber mount, thats allways worked for me.
Re: transmission mount----solid or poly [Re: wyoming] #734712
06/28/10 11:26 AM
06/28/10 11:26 AM
sg66mopar Offline
sg66mopar  Offline
Had a rubber mount for 20 years. Now with the B1 power I've broken two belhousings in under 50 passes. Went to a solid mount last week. We'll see what happens.
Re: transmission mount----solid or poly [Re: sg66mopar] #734713
06/28/10 11:31 AM
06/28/10 11:31 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mid plate ?
Re: transmission mount----solid or poly [Re: WILD BILL] #734714
06/28/10 12:15 PM
06/28/10 12:15 PM
sg66mopar Offline
sg66mopar  Offline
Yeah, front and rear 1/4" aluminum plates, plus engine limiters on both sides.
Re: transmission mount----solid or poly #734715
06/28/10 02:51 PM
06/28/10 02:51 PM
Kissimmee Fl.
Kissimmee Fl.
Put enough power through it, and a tube chassis will flex.
yeah I suppose that is true but spoke with a local chassis builder that builds some high end stuff and he said that is the only way they leave his shop and I am talking stuff with 1500+ hp so thats more than I will ever throw at this car.
