mopar motor issues #734612
06/27/10 09:43 AM
06/27/10 09:43 AM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
I bought a six pack 340 car to restore and the motor was aready rebuilt. So i put the motor in and proceeded to get it running. It ran like crap and after about 20 min i started knocking and i had to shut it down. I then pulled it and took it to a local engine shop, after they looked it over they said it needs a total rebuild 30 over new pistons and so on $4,000 worth. I get the motor back and get ready for the 1/2 hour break in period. durring the 1/2 hour oil started to come out of the radiator over tube. I then pulled the drain plug to take out the break in oil to replace it with regular oil and i got only water. I then pulled the motor again and took it back. They found that there was a hole in one of the oil galleys and they patched it and rebuilt the motor again. First what do you thin happened? remember durring the first run i didn't have oil in the water.
Next the engine goes back in and before i did the break in again i filled the radiator up with water and the water comes out of a new crack in the head. What do you think about this? Remember there was no crack on the first and second run
Is this all just bad luck or ???????
Thank you
Re: mopar motor issues [Re: mattpar] #734613
06/27/10 09:54 AM
06/27/10 09:54 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not Mopars fault.
Unless you knew the person that you bought it from or was a reputable shop with a warrenty - check things out.
On second go - Find a machine shop that checks things out.
Re: mopar motor issues [Re: MoparforLife] #734614
06/27/10 09:57 AM
06/27/10 09:57 AM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
can a old patch get boiled out durring block cleaning? have you ever heard of a hole in the oil gally. And there couldn't been a old crack that all of a sudden appeared in the head. If it was crack it would have leaked at first right?
Re: mopar motor issues [Re: mattpar] #734615
06/27/10 02:48 PM
06/27/10 02:48 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Oil out of the radiator.
Water out of the oil pan...
Really now...
This thread is a new version of this Epic Thread:
The oil change heard around the world
Nice try. You should have gone with this one:
I got married last weekend.
Re: mopar motor issues [Re: Commando1] #734616
06/27/10 04:02 PM
06/27/10 04:02 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Did you pay to have the block and heads magnifluxed before you started your rebuild. Magnifluxing both the block and heads and sonic checking the block is usually worth the added cost.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: mopar motor issues [Re: pittsburghracer] #734617
06/27/10 10:33 PM
06/27/10 10:33 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
the heads and block were both magna fluxed and showed nothing
And yes i wish i was lieing, the oil pressure pushed up to the water galley and put 60lbs against the water pump and filled the radiator. have you ever heard of a hole in the oil galley like that? and surley the shop couldn't have created that could they?
Re: mopar motor issues [Re: mattpar] #734618
06/27/10 10:52 PM
06/27/10 10:52 PM
PA.
"Little"John
"Little"John
PA.
Appears to be a common mistake with a simple fix. The engine builder put the drivers side head gasket on the passenger side by mistake. Simply remove both heads and inter change head gaskets side to side. Reinstall heads and add fluids,throw a hand full of salt over your right shoulder cross your fingers and start engine. During engine breakin DO NOT LET RPM DROP BELOW 9500 RPM.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: mopar motor issues [Re: pittsburghracer] #734619
06/27/10 10:56 PM
06/27/10 10:56 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
they disasembled the motor after pressure tests and found holes in the oil galley that travels from the block to the heads
I'm baffled, why would there be a hole there at all and not show until the rebuilt it
Re: mopar motor issues [Re: mattpar] #734620
06/27/10 11:01 PM
06/27/10 11:01 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
can i assume no one thinks this story is true? The fix for the hole was to mill out the galley and sleve it with a sleve.
Re: mopar motor issues [Re: pittsburghracer] #734621
06/28/10 07:43 AM
06/28/10 07:43 AM
Commando1 Offline
Commando1  Offline
I agree. happens all the time. Especially on the Hemi small blocks.
The 440 Source Galley Sleeves are junk.
Re: mopar motor issues [Re: Commando1] #734622
06/28/10 06:57 PM
06/28/10 06:57 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
so a hole in a oil galley is not totaly uncommon?
And also when i put the engine back in for the third time i found out the back of the head towards the fire wall was cracked and leaked water. Can that be just bad luck or did something happen?
All of this has got me bummbed out, as you can imagine. also does anyone know a professional weld shop to weld the crack properly
Re: mopar motor issues [Re: mattpar] #734623
06/28/10 07:52 PM
06/28/10 07:52 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Are you absolutely sure you are getting the same parts back that you dropped off. Some unscrupulous folks will take advantage of you if you aren't careful. Mark your parts and know what you have.
Just what were you getting sleeved in the oil gallery? Sounds like your re builder is full of some thing.
Re: mopar motor issues [Re: mattpar] #734624
06/28/10 07:57 PM
06/28/10 07:57 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Commando1, I'd never seen "married". Thanks
Re: mopar motor issues [Re: RodStRace] #734625
06/28/10 09:34 PM
06/28/10 09:34 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
so you ran it before rebuild and no problems like these. then after rebuild these problems show up?
Re: mopar motor issues [Re: bboogieart] #734626
06/28/10 11:21 PM
06/28/10 11:21 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
This is a T/A car the block has T/A cast in it and the numbers are the same, so they would have had to have a T/A motor to replace it with . as far as what was tubed i didn't see they just said there was a hole about the size of a pencil eraser
Re: mopar motor issues [Re: d-150] #734627
06/28/10 11:26 PM
06/28/10 11:26 PM
Winesburg Ohio
mattpar Offline OP
mattpar  Offline OP
Winesburg Ohio
Yes i ran it but it had something majorly wrong internaly but no oil in the water and no head leaks. Then it went to get rebuilt and after that is when the oil was pressured into the water. out it came again and the hole was repaired, then back in it went then a leaking crack in the head?
Re: mopar motor issues [Re: mattpar] #734628
06/29/10 08:18 AM
06/29/10 08:18 AM
Commando1 Offline
Commando1  Offline
You can plug your crack with Mighty Putty.
Re: mopar motor issues [Re: Commando1] #734629
06/29/10 10:18 AM
06/29/10 10:18 AM
PA.
"Little"John
"Little"John
PA.
I keep my old chewing gum on my bed rail for occasions like this but for the best repairs stick with the Dent-tine brand. Apply, sand, and paint as needed.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: mopar motor issues [Re: mattpar] #734630
06/29/10 01:50 PM
06/29/10 01:50 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
How about some pictures of what your talking about.
Re: mopar motor issues [Re: Jwilli500] #734631
07/01/10 02:23 PM
07/01/10 02:23 PM
Commando1 Offline
Commando1  Offline
