fender tag what is correct
#734554
06/27/10 08:41 AM
06/27/10 08:41 AM
Posts: 1,893 michigan
70 buzz
michigan
I see so many fender tags that are painted with one screw painted or both and the entire tag painted but the majority I see is both screws and vin painted. When I restored my car there were no evidence of the screws being painted nor the vin tag. I'm guessing it depended on the plant it came from but mine is a 70 lynch road car. I left the tag unpainted along with the screws.
Re: fender tag what is correct
[Re: JohnRR]
#734557
06/27/10 11:30 AM
06/27/10 11:30 AM
Posts: 21,508 N.E. OHIO, USA
A12
N.E. OHIO, USA
Lynch Rd. tag is usually not painted , if yours was not then I would clear it and put it on that way .
John are you sure about that... I got beat up by an "expert" on fender tags on an A12 of all things and now that high ranking A12 has a painted fender tag, bent and one screw not painted . Funny thing was the tag was not painted or bent when the question was asked how it should be, go figure
MikeR
[Re: JohnRR]
#734558
06/27/10 12:08 PM
06/27/10 12:08 PM
70 buzz
michigan
That is how it is on the car right now plain and the screws unpainted. I have been told it was wrong but I know someone clarified it that it was that way on this board more than one person. Ok Paul J. chime in I know you know.
[Re: 70 buzz]
#734559
06/27/10 12:12 PM
06/27/10 12:12 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Well then you surely want to do what some pASSer by at a car show is telling you.
Not that I or any of the other members that have put alot of thought into this very subject are the final authority either.
[Re: A12]
#734560
06/27/10 12:14 PM
06/27/10 12:14 PM
JohnRR
U.S.S.A.
MikeR
I really don't know how to respond to something like that.
[Re: A12]
#734561
06/27/10 12:31 PM
06/27/10 12:31 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
MikeR
I know St. Louis left one screw in and bent up the tag for paint. Tags and one screw got painted, the other screw is not. Lynch Rd cars from what I understand had the tag hanging from the roof in the car while being painted, so I would guess the amount of paint if any would differ from car to car. Both screws would also be unpainted.
[Re: Pacnorthcuda]
#734564
06/27/10 07:23 PM
06/27/10 07:23 PM
70 buzz
michigan
Here is a picture of my tag and I'm not going to do anything to it
[Re: Pacnorthcuda]
#734569
06/27/10 10:36 PM
06/27/10 10:36 PM
70 buzz
michigan
Wow...it may not have many options but it has a few really good ones!
The good thing it is #matching with the build sheet
[Re: Paul Jacobs]
#734572
06/27/10 11:17 PM
06/27/10 11:17 PM
A12
N.E. OHIO, USA
As stated, Lynch Rd tags were not painted on the fender, usually just a mist of paint at best. Here are 2 examples, 1 which shows quite a bit of overspray, the other almost none. Both 69 cars.
Thanks Paul, I’ve perpetuated or beat this Painted or Unpainted Lynch Road fender tag horse to death and then kept beating it for a couple of decades now and it was more for laughs for a long time. I thought at first it was just the A12 cars because my A12 (Lynch Road of course) fender tag was completely bare and someone back in the’90’s thought that was a trait of A12’s and pointed out that John Dal. /roadrunnerJD original black A12 had an unpainted fender tag. At first I thought it might have been because a new or second tag might have been made for the A12 package after the original and later found out that there were lots of original Lynch Road fender tags in ‘68/69 with little or no paint on them. More research and hundreds of fun posts on the “painted or unpainted fender tags” and we found out that Lynch Road cars had the tag hanging by a paperclip and some got lots of paint and most got overspray but one thing they DIDN’T get WAS BENT IN THE UPPER LEFT CORNER with one screw left in (pun on the LEFT). So my new dig is “Bent or Unbent” Lynch Road fender tag? You can find lots of Lynch Road fender tags that were painted or re-painted over the years but if someone didn’t bend them they were NOT bent at Lynch Road back in ‘68/’69. Bent or Unbent Lynch Road fender tags…………………paint optional
MikeR
[Re: A12]
#734573
06/27/10 11:24 PM
06/27/10 11:24 PM
A12
N.E. OHIO, USA
Here's my A12 fender tag and there are two "telltales" on this beside the no paint on the tag, one is the lack of a bend crease in the upper left corner and the other is the inspector's sideways "X" on the left side that could not have been put there if the tag was screwed down by a left side fender tag screw. MikeR Yep that's Y4 Spanish Gold
