Hughes Cams #733947
06/26/10 01:21 PM
06/26/10 01:21 PM
NW Minnesota
Maximus_Wedges Offline OP
NW Minnesota
I'm interested in a hughes HTL series Flat Solid cam for my new 512 project. The cam I'm looking at is the 6872. Lift @ my 1.6 is .651 and .661
Duration @ 50 is 268 and 272. Any one run this cam on the strip? Hughes claims it's a maximun profile .904 cam. I wonder how it is on valve train parts?
Re: Hughes Cams [Re: Maximus_Wedges] #733948
06/26/10 04:07 PM
06/26/10 04:07 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i have that one with a 1.5 rocker. seems to work just fine
Re: Hughes Cams [Re: 493_DART] #733949
06/26/10 05:55 PM
06/26/10 05:55 PM
NW Minnesota
NW Minnesota
Thanks for the reply 493 Dart. Hughes says this cam series has a wide power band 3200-7100. Did you find this to be the case. Would you share info about your set up? or PM me if you like.
Thanks again
Re: Hughes Cams [Re: Maximus_Wedges] #733950
06/26/10 09:24 PM
06/26/10 09:24 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i have run that very cam. easy on parts if broken in correctly. also, keep plenty of zinc in the oil. currently, i have one of his cams with eddy heads it has run some 5.91's 1/8 mi. the one we have now is one of his bigger cams.
Re: Hughes Cams [Re: tjmarcus1] #733951
06/26/10 11:36 PM
06/26/10 11:36 PM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I'm using that cam right now in my 496, no problems makes good power. 10.22@127 in a 3400 dart, 1.40 60 ft.....Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: Hughes Cams [Re: Maximus_Wedges] #733952
06/27/10 03:15 AM
06/27/10 03:15 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Thanks again
Its a mean cam--i dont know how high it will pull as Im setup for lower rpm this year. i cant get good weather or the car always has a gremlin the past 2 months....so i still dont know its potential.
Follow Hughes break-in procedure for sure.
I use Brad Penn oil with some Hughes additive
493 , 11.5:1 with standard port eddy Rpm heads
1.5 Harlands
Isky 8005-A springs , 4K converter
Ive been shifting around 5800 , i know that cam will pull much higher..its pulling through the 1/4
In a perfect world I will get to a track for Test-n-tune and it will be great weather and my bugs will be worked out--
the car definitely has 10.30's in it.
