Early 73 Challenger engine ground #733871
06/26/10 09:43 AM
06/26/10 09:43 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Does anyone know if the early 73 Challengers had an engine ground from the back passengers cylinder head to firewall? I thought I remembered there being one but I can't figure out where it mounts to the firewall.
The later built cars have a ground strap that bolts to the firewall just to the left of the voltage regulator. Here is a pic of that setup.
My car doesn't have that hole drilled in the firewall. I've looked back at all my old pics and don't see any strap back there. Someone on Cuda/Challenger.com looked at his 73 Cuda which was build around the same time as my car. He said there is no strap on the back of the engine.
Re: Early 73 Challenger engine ground [Re: burdar] #733872
06/28/10 06:30 PM
06/28/10 06:30 PM
Omaha
road Offline
road  Offline
Omaha
Looked at my September build 73. Don't see any hole for a ground strap.
Re: Early 73 Challenger engine ground [Re: road] #733873
06/28/10 07:54 PM
06/28/10 07:54 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
So are you saying that the only ground wire is off of the front drivers side head? I wonder if 72's are the same way? The ICCA fastener guide shows 73-74 as having a ground strap in the back. The factory must have added one after September 72. Thanks for looking.
Re: Early 73 Challenger engine ground [Re: burdar] #733874
06/28/10 09:55 PM
06/28/10 09:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A buddy of mines '74 challenger has the ground on the right rear. I'll get the SBD tomorrow afternoon
Re: Early 73 Challenger engine ground [Re: gtx6970] #733875
06/28/10 10:09 PM
06/28/10 10:09 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
The very early 73's don't seem to have the hole in the firewall for the rear ground strap that other 73's do. The 74 should have one in the same possition as the picture I posted.
My cars SBD is 927.
Re: Early 73 Challenger engine ground [Re: burdar] #733876
06/30/10 11:00 PM
06/30/10 11:00 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
73 E bodies did not have a ground strap. Just the negative battery ground on the driver's side front of cylinder head.
Re: Early 73 Challenger engine ground [Re: denfireguy] #733877
06/30/10 11:43 PM
06/30/10 11:43 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Thank you.
At some point after September 72, they started putting them on though.
Re: Early 73 Challenger engine ground [Re: burdar] #733878
07/01/10 03:03 PM
07/01/10 03:03 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
hey Darren,
my 72 Challenger was built on 12/7/71 and i didn't have the ground strap.
Greg
Re: Early 73 Challenger engine ground [Re: joelson6] #733879
07/01/10 03:05 PM
07/01/10 03:05 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
