Re: broken trans cooler fitting
[Re: chache876]
#733813
06/26/10 08:09 AM
06/26/10 08:09 AM
Posts: 15,487 Florida
scratchnfotraction
done a few brass ones just use a square ez out on it,nothing behind it your gonna hit with the ez out shouldnt be that big a deal..under the car on the front one can be a little cramped though but not to hard to back out good luck
[Re: chache876]
#733816
06/26/10 04:26 PM
06/26/10 04:26 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Ez-outs are usually pretty hard, too hard to drill out with a normal drill bit.
The threads in the case are 1/8"-27 NPT.
[Re: chache876]
#733818
06/27/10 10:49 AM
06/27/10 10:49 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
I was able to get the fitting out. I had to drill it out some more and was able to squeeze the next size extractor in there and it finally broke loose, thanks guys
How did you get the chips from drilling out? Is that passage direct to the valve body or to the front pump ? If it's from the front pump I would put a hose on it into a drain pan and start the engine and let it pump out a qt. or so so you don't send the debris into the cooler and eventually your rear support.
[Re: JohnRR]
#733819
06/27/10 02:18 PM
06/27/10 02:18 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
I found a picture in my service manual that showed a picture of which port went where. Removed the valve body and blew some air through it so it blew the debris out the cooler line port.
Good idea I had definitely planned on running a little bit of fluid with the line disconnected when I start it back up in case I missed anything.
