DynoMax Mufflers #733450
06/25/10 05:29 PM
06/25/10 05:29 PM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Anyone have a set of DynoMax UltraFlo Welded mufflers on their Mopars
And How do you Like Them?
I have 40 series FloMasters on my 69RR, can not stand the
Drone sound you get from them
Re: DynoMax Mufflers [Re: TOMRR] #733451
06/25/10 06:43 PM
06/25/10 06:43 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Got-em on my Bee and love em!
Re: DynoMax Mufflers [Re: TOMRR] #733452
06/25/10 07:12 PM
06/25/10 07:12 PM
Locomotion Online content
Locomotion  Online Content
I have them on my race car with TTI headers and X-pipe ending at the rear end housing. After tuning with open headers for years, put these on, tuned a bit more and went faster!
I can hear my Holley blue pump at idle but got compliments at WOT.
Re: DynoMax Mufflers [Re: TOMRR] #733453
06/25/10 07:47 PM
06/25/10 07:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Flow bastards suck! I like mine 3" X pipe dump before the axle only complaints I get at 10.6 is too quiet???
Re: DynoMax Mufflers [Re: TOMRR] #733454
06/25/10 09:01 PM
06/25/10 09:01 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
My dad has them on his 440 Coronet, with an H pipe, turned down after the axle. Sounds good, not too loud, no noticeable resonance.
Re: DynoMax Mufflers [Re: Exit1965] #733455
06/25/10 10:11 PM
06/25/10 10:11 PM
Rockford,IL
71Dusterdan Offline
71Dusterdan  Offline
Rockford,IL
Got a set on my f250, nice and mellow, and surprisingly quiet at idle and cruise, not obnoxious when I get on it. I would use them again, and again!
Re: DynoMax Mufflers [Re: 71Dusterdan] #733456
06/25/10 10:34 PM
06/25/10 10:34 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I have 3" Diameter ones with turn downs in front of the axle. Has a real nice sound at idle but really barks at full throttle. I love mine.
Re: DynoMax Mufflers [Re: TOMRR] #733457
06/25/10 10:46 PM
06/25/10 10:46 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I've had the same set on two cars now. When I had them on my old Duster I used a "H" pipe. When they went on the 'Cuda I went with a "X". Both cars had very similar engines and TTI headers. The only difference was between "H" and "X" was the fact that the Duster had 2 1/4 tailpipes and the 'Cuda is 2 1/2 all the way through. No resonance with either setup. Personally I prefer the sound of the "X". Both engines made good torque, they had different transmissions [ 727 vs 5 speed manual ] and a few other differences so it's a little difficult to make an "apples to apples" comparison as to which "X" vs "H" gave the best performance. Both cars are fairly loud, but not so bad that you can't hear the radio or carry on a normal conversation. I wouldn't hesitate to buy another set.
Re: DynoMax Mufflers [Re: 5spdcuda] #733458
06/25/10 11:03 PM
06/25/10 11:03 PM
Maryville tn
67coronetman Offline
Maryville tn
So i have never used the Dynomax do they have a good sound and whats the cost i will be running 3" with turn downs.!
Old car are me......
Re: DynoMax Mufflers [Re: 67coronetman] #733459
06/25/10 11:19 PM
06/25/10 11:19 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
The sound is fairly deep, but not quite as much as Flowmasters. Personally I think Flowmasters sound a little better from OUTSIDE the car. Inside is a different story. Dynomax won't drive you nuts inside the car. As I said earlier the choice of an "X" or "H" pipe also affects the sound. The "X" gives what I would describe as a somewhat Nascarish sound under heavy throttle.
Re: DynoMax Mufflers [Re: 67coronetman] #733460
06/25/10 11:23 PM
06/25/10 11:23 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Forgot to give cost. Latest Jegs has 3in. as follows: center in and out=$81.99, offset/center=$73.99, offset/offset=$81.99.
Re: DynoMax Mufflers [Re: 5spdcuda] #733461
06/26/10 12:17 AM
06/26/10 12:17 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I've used them and love them. Similar in design but a fuzz cheaper is the Magnaflow welded mufflers. I've got a set of the Magnaflows on a 440 now. The mufflers are right before the axle and then I have a small set of Summit 14" long glass pack style mufflers right before the turn downs at the bumper and it sounds great. It has a great low rumble at idle, a mild growl when you get in the gas a bit, and then you know its got a 440 when you romp it.
Re: DynoMax Mufflers [Re: Chilort] #733462
06/26/10 08:50 AM
06/26/10 08:50 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Here is a very short clip of my dad's car with the ultra flows.
http://www.youtube.com/watch?v=yuYm6LlJCW8
I agree Magnaflows are probably the same! I have them on my car (440 Dart) with headers/an X pipe and this is how it sounds:
http://www.youtube.com/watch?v=h3d-jleaRhM
Towards the end is some idling sound.
That was before I had much of an interior in the car. Now with carpet it is actually pretty quiet inside.
Re: DynoMax Mufflers [Re: Exit1965] #733463
06/26/10 08:53 AM
06/26/10 08:53 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
and here are the magnaflows breathing a bit harder
http://www.youtube.com/watch?v=K7aWoquOWWA
Re: DynoMax Mufflers [Re: TOMRR] #733464
06/26/10 09:27 AM
06/26/10 09:27 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Thanks for all the replys, I can't wait to get them on my RR
Tom C.
Re: DynoMax Mufflers [Re: TOMRR] #733465
06/26/10 09:32 AM
06/26/10 09:32 AM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Tom, before you pop for the UltraFlo Welded, look into the new Dynomax VTs. You could run the 17956 and have a sweet sound, no drone, and plenty of noise at WOT. They really are pretty darn slick. We have three sets we are playing with right now.
And, there is rebate on them too so for $75 you get state-of-the-art technology, great sound, no drone, and all stainless steel body and tubes.
Tom
Re: DynoMax Mufflers [Re: TOMRR] #733466
06/26/10 03:12 PM
06/26/10 03:12 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
got them and love them,can have a conversation when cruising,yet they openup nice when you punch the go pedal
Re: DynoMax Mufflers [Re: Tom Hand] #733467
06/26/10 04:26 PM
06/26/10 04:26 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Tom
Please post a sound clip!!!
Re: DynoMax Mufflers [Re: Tom Hand] #733468
06/26/10 04:53 PM
06/26/10 04:53 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Tom
I plan on running Dynomax mufflers on my Road Runner. But I'm not sure I like the idea of a spring/back pressure operated butterfly valve in my muffler. I'm sure it works fine when new, but what happens if/when the valve corrodes shut due to condensation/soot? What happens if the spring/linkage breaks?
Just throwing it out there...
Re: DynoMax Mufflers [Re: CompSyn] #733469
06/26/10 07:23 PM
06/26/10 07:23 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
CS, very good questions. With them constructed from all st. st. parts, corrosion is not as big of worry to me. They are cheap enough right now that I could live with the worry of the spring eventually fatiguing. I think it is 302 or one of the spring alloys of st. st. so it likely is long lived as well.
Seriously though, we just put a set of 17956's on a 12 second 68 360 barracuda. I have two more with the weaker spring (17156) coming this week and we will do a comparison between them to see what affect the spring rate has on back pressure and sound level at various RPMs. It is weird that such a short muffler, with a 3" core with minimal packing, has such little resonation and roar.
I have had 340s since 1978 and they are very tough to keep from resonating from 1800 to 2300 RPM. This muffler seams to prevent that roar very nicely.
As soon as we get the whole system sealed and leak free, I will try to get some very good sound recordings to share along with the data we plan to collect. Should get measurements later this week.
Tom Hand
