installing alternator with 2 field posts on 68 charger #732498
06/23/10 11:43 PM
06/23/10 11:43 PM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
Wondering if anyone knows if a 1977 style alternator thst has the square in the back and 2 field tabs can be wired in to be used on a 1968 charger that has 1. Thanks Tim
Re: installing alternator with 2 field posts on 68 charger [Re: ts70rt] #732499
06/24/10 12:50 AM
06/24/10 12:50 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Yes just ground one of the fields to the back of the alternator.
Re: installing alternator with 2 field posts on 68 charger [Re: gtx69] #732500
06/24/10 08:11 AM
06/24/10 08:11 AM
scratchnfotraction Offline
another good upgrade is a elect solid state voltage regulator to loose the old points style thats on the 68 model
Re: installing alternator with 2 field posts on 68 charger [Re: scratchnfotraction] #732501
06/24/10 09:20 AM
06/24/10 09:20 AM
Andrewh Offline
Andrewh  Offline
most auto parts stores carry the new electronic type for the 68 now. you have to special order the points type.
Re: installing alternator with 2 field posts on 68 charger [Re: Andrewh] #732502
06/24/10 11:58 PM
06/24/10 11:58 PM
ts70rt Offline OP
ts70rt  Offline OP
I have the blue performance regulator if that matters
