Pre-oiling questions #73212
06/13/08 03:39 PM
06/13/08 03:39 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
Hey guys, just pre-oiled my '73 360 motor in my 69 dart, just a couple of questions... i preoiled for about 2 minutes total (had to stop to fix a leak, then continued) and i didnt see any oil coming out around the valvetrain or the top end of the motor at all... i did hear the lifters pump up though... im using crane gold rockers if that makes a difference... also... assuming that i did pre-oil correctly, how long do i have to get the motor running before i should pre-oil again? or once its done, it is done?... thanks!...
kevin
Re: Pre-oiling questions [Re: dakrt23] #73213
06/13/08 03:41 PM
06/13/08 03:41 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Where you sure to rotate the crank as you primed it? You want to make sure you do that, so you get oil up to all the passages
Also, once you start it, no need to prime it again...you preoil it to make sure you have oil everywhere (top end too actually) before the first fire up.
Re: Pre-oiling questions [Re: OzHemi] #73214
06/13/08 06:58 PM
06/13/08 06:58 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
Ill make sure to do it again while turning the crank...
my question was that if i pre-oiled it now... do i have to get it started within a certain time frame (because i have other loose ends to tie up before starting)... or once i pre-oil it will stay pre-oiled until i start it up?...
Re: Pre-oiling questions [Re: dakrt23] #73215
06/13/08 07:50 PM
06/13/08 07:50 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I would pre-oil it again right before start up.
The rocker arm oiling is "timed" via two holes in the cam shaft that are only lined up during a certain angle during engine rotation. So you must slowly rotate the crank while you are priming. Once the holes in the cam are lined up with the holes in the engine block the oil will go up to the rocker shaft.
Re: Pre-oiling questions [Re: 69Cuda340S] #73216
06/13/08 07:52 PM
06/13/08 07:52 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Me too
Re: Pre-oiling questions [Re: OzHemi] #73217
06/14/08 01:35 PM
06/14/08 01:35 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I spin the engine with a remote starter switch while spinning the primer shaft with a drill.
