another 440 build needs help with cam options #731852
06/23/10 10:23 AM
06/23/10 10:23 AM
CT USA
N
Nick Mineau Offline OP
N
CT USA
hi
im working on a 440 thats going into my duster.
HERES THE SPECS.
the motor is true 10to1 squeeze with 516 heads. the heads have been upgraded to the 1.74 exaust valve/2.08 intake. compition valve gob and mild port work includin bowl blending and gasket matching, all donE on a flow bench by a machinest. no flow numbers yeat still a work in progress. ch4b intake.shumaker headers.
the car weighs 3300lbs with 3.23 gear and a 2200 stall and 28x11.5 slicks
i need help on what cam to choose for best 1/4mile times+street manners.
im looking at the comp xe274 camshaft or the xe 268 but im very open to sugestions/
thanks nick
Re: another 440 build needs help with cam options [Re: Nick Mineau] #731853
06/23/10 10:41 AM
06/23/10 10:41 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
If you are keeping that gear and stall I would run the xe268.
Re: another 440 build needs help with cam options [Re: Nick Mineau] #731854
06/23/10 10:51 AM
06/23/10 10:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That's a mighty tight converter.
mild cam (almost need the 262) 10 to 1 and iron heads I can see a race gas motor.
Re: another 440 build needs help with cam options [Re: Dodgem] #731855
06/23/10 10:55 AM
06/23/10 10:55 AM
CT USA
N
N
CT USA
I was planning on 93. changing the convoter is a option. the car is farly light which is why i thought i could get away with it.
Re: another 440 build needs help with cam options [Re: Nick Mineau] #731856
06/23/10 10:57 AM
06/23/10 10:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
with that stall and gear I guess you need more grunt than power. I'll guess somthing in the 220's-230's - 460-480 lift will work fine. Anything bigger and you'll need to go up on the gear and converter.
Coming soon!!!!
Re: another 440 build needs help with cam options [Re: Mr.Yuck] #731857
06/23/10 11:03 AM
06/23/10 11:03 AM
CT USA
N
N
CT USA
k
i dont want to change the gear because i drive the car alot. sounds like the xe 268 is the cam for me. heres the specs. http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=707&sb=2
also looking into these two
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=706&sb=2
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=708&sb=2
Re: another 440 build needs help with cam options [Re: Nick Mineau] #731858
06/23/10 10:26 PM
06/23/10 10:26 PM
CT USA
N
N
CT USA
main goal is best 1/4 mile et
Re: another 440 build needs help with cam options [Re: Nick Mineau] #731859
06/24/10 08:37 AM
06/24/10 08:37 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This is what I would suggest a 3000 stall minimum and 3.54 gears.
You have too much compression for mild cams and to tight a converter for better cams.
The quench of the 516 may help some. I would go 3000 stall and at least the biggest cam you are looking at
