Peg Leg #731766
06/23/10 01:51 AM
06/23/10 01:51 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
What kind of gear ratio came on 70 383 Road Runners with non sure grip rears?
Re: Peg Leg [Re: tt455] #731767
06/23/10 01:53 AM
06/23/10 01:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
In many cases, the 3.23 ratio was the standard ratio of most 383 and 440 cars.
Re: Peg Leg [Re: Kern Dog] #731768
06/23/10 07:20 AM
06/23/10 07:20 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks.If that's the case and I have a sure grip carrier,will that gear set from the open rear fit in this one?
Re: Peg Leg [Re: tt455] #731769
06/23/10 11:54 AM
06/23/10 11:54 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
It depends on the case #s. There are different cases. Look for #s cast into tne side of the case near the snout.
Re: Peg Leg [Re: tt455] #731770
06/23/10 01:36 PM
06/23/10 01:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Only 1 gear ratio 3.23 , any other gear ratio available in a 1970 RR wit ha 383 and auto trans would have been with a suregrip .
As far as swapping gears to your suregrip chuck , as long as it's the same case numbers. Gars do not swap between the different carriers BUT you can put that suregrip in your open chuck as long as you use the correct bearings for the sure grip being used , cone and clutch used a different bearing , the bore in the chuck is the same but the carrier is different and requires it's own bearing and race.
Re: Peg Leg [Re: JohnRR] #731771
06/23/10 01:52 PM
06/23/10 01:52 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks to all for your replies. Both carriers read 489. The 3:23 sure grip ring and pinion are worn and was advised not to use them for I might get a humming sound from it.
So I would like to use that carrier with the sure grip internals for the 3:23 open gears that are in the car now.
Re: Peg Leg [Re: tt455] #731772
06/23/10 04:32 PM
06/23/10 04:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can do that , just go thru the suregrip in the one with worn out gears , it's a cone type , they are JUNK by design , if the gears are worn the cone type is probably on it's last leg also .
