'99 Dakota w/ 3.9 won't idle.... #731692
06/22/10 10:33 PM
06/22/10 10:33 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
My sons Dak won't idle. I can raise the idle w/ the gas pedal and drive it. What do I look for? If it was a 'yota I would know the idle air control valve was sticking- does the Dak have something similar? Thanks.
Tim
Re: '99 Dakota w/ 3.9 won't idle.... [Re: I_bleed_MOPAR] #731693
06/22/10 11:19 PM
06/22/10 11:19 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would take the iac motor out and clean it and the passaage out with carb cleaner or equiv. It's on throttle body, and should have 4 wires in the connector.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: buildanother] #731694
06/23/10 01:37 AM
06/23/10 01:37 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
A few years ago my '96 Dak 3.9 had the same symptons. Pulled the IAC valve, cleaned it & it's passage, ran like a top afterwords.
It was on the backside of my throttle body, IIRC.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: vdriver] #731695
06/23/10 11:43 AM
06/23/10 11:43 AM
Tampa, Fl
valiantboy Offline
super gas
valiantboy  Offline
super gas
Tampa, Fl
yeah i have to agree. thatd be the first suspect.
I'm WAY too baked to drive to the devil's house.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: valiantboy] #731696
06/23/10 12:14 PM
06/23/10 12:14 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
agree with everyone else just when you clean it becareful not to touch the plunger or you could break it. I usually take the IAC out and just spray it with carb cleaner, let it sit for a couple minutes then put it back in. No not touch it or wipe off the carbon.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: '99 Dakota w/ 3.9 won't idle.... [Re: blk00rt] #731697
06/23/10 12:33 PM
06/23/10 12:33 PM
Ohio
Todd Offline
Todd  Offline
Ohio
???? The plunger is made of steel...Go ahead and clean away... The hole point of removing it is to remove carbon from the passages and the IAC. Cleaned tons of them that way.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: Todd] #731698
06/23/10 01:46 PM
06/23/10 01:46 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
Don't laugh, but my 97 would take spells it wouldn't idle. One night it wouldn't start, cables were funky looking, not corroded but just funny looking, cleaned them and it starts better, and the idle situation went away also.
Mine's IAC went bad right after I got it, it wouldn't idle steady, but never died
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: '99 Dakota w/ 3.9 won't idle.... [Re: Todd] #731699
06/23/10 09:25 PM
06/23/10 09:25 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
todd you are correct, however there is electronics behind the plunger and pushing in and out on the plunger too hard could cause damage to the electronics thus destroying the IAC.
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: '99 Dakota w/ 3.9 won't idle.... [Re: blk00rt] #731700
06/23/10 09:47 PM
06/23/10 09:47 PM
Ohio
Todd Offline
Todd  Offline
Ohio
There's no need to push and pull on the plunger to clean it. Some cleaner and a small brush works just fine. Idle strategies will have to relearn due to increased airflow.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: I_bleed_MOPAR] #731701
06/23/10 10:34 PM
06/23/10 10:34 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Might also be a weak battery.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: FuryUs] #731702
06/24/10 11:19 AM
06/24/10 11:19 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
My father's 98' 5.2L Durango wouldn't idle either; it would just spit and sputter until you pressed the throttle down a little ways and then it would even right out. Turned out to the throttle position sensor.
Re: '99 Dakota w/ 3.9 won't idle.... [Re: MarkZ] #731703
06/24/10 05:54 PM
06/24/10 05:54 PM
Buford, GA
Buford, GA
Cleaned the ISC valve last night (and the battery terminals, just to be safe ) and the warm idle was smoother. It idled fine this morning on cold start. Thanks, guys.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
