Brakes on my 66 question ?? #731621
06/22/10 09:26 PM
06/22/10 09:26 PM
ar
bobs68 Offline OP
bobs68  Offline OP
ar
We changed over to a dual line master cylinder about a year ago. The brakes were never that good to start with. But as time goes by the peddal is getting more like pushing on a rock. We changed all the lines with the master cylinder. Is the master cylinder bad?? They are manuel brakes.
Re: Brakes on my 66 question ?? [Re: bobs68] #731622
06/23/10 12:03 AM
06/23/10 12:03 AM
Pedal is high and tight but pedal pressure doesn't produce the same braking force as it used to? (& it wasn't that great in the 1st place?) I'd start by opening up each drum & a good basic visual inspection for anything abnormal like contaminated linings.
