anyone make spool for 8 1/4 rear #731497
06/22/10 05:36 PM
06/22/10 05:36 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
Does anyone make a spool for 8 1/4 rear
Re: anyone make spool for 8 1/4 rear [Re: 75dusted] #731498
06/22/10 05:47 PM
06/22/10 05:47 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Lincoln is the only one I know of
funny they make a spool for the two most popular toyota rears but non for the 8 1/4
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: anyone make spool for 8 1/4 rear [Re: HealthServices] #731499
06/22/10 07:21 PM
06/22/10 07:21 PM
MD
75dusted Offline OP
75dusted  Offline OP
MD
Do they have a website or a place to buy one?
Re: anyone make spool for 8 1/4 rear [Re: 75dusted] #731500
06/22/10 07:31 PM
06/22/10 07:31 PM
DE
Ply72rr Online content
Ply72rr  Online Content
DE
I think he means a Lincoln welder.
Re: anyone make spool for 8 1/4 rear [Re: Ply72rr] #731501
06/23/10 10:32 AM
06/23/10 10:32 AM
CT USA
N
Nick Mineau Offline
Nick Mineau  Offline
N
CT USA
weld it up nice. you will NEVER have a problem have done it in countless jeeps for off roading with 8 1/4 axles. trust me you will break the driveshaft/ujoint/ringandpinon/or axleshaft before the spider gears welds. just make shure it is very clean before welding. i use brake clean. then stand back and light the remaning brake clean on fire befor you weld to make shure it doesnt flame up once you start welding and catch yourself onfire. KEEP A FIREEXTINGUSHER NEARBY GEAR OIL/BRAKECLEAN IS VERY FLAMABLE. A CONTROLED BURN IS BETER THAN BURNING THE HOLE CAR DOWN
Re: anyone make spool for 8 1/4 rear [Re: Nick Mineau] #731502
06/23/10 12:54 PM
06/23/10 12:54 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i would use caution doing this, i seem to remember a thread around here or somewhere else sometime ago about using breakclean on something that is getting welded,due to the breakclean reacting with the weldinggas and heat and turning into some very very nasty gas..
Re: anyone make spool for 8 1/4 rear [Re: 1Fast340] #731503
06/23/10 01:20 PM
06/23/10 01:20 PM
So Cal
So Cal
Yes brake clean or carb clean very bad in the presents of welding, can kill you or do some bad stuff to your body.
'Lincoln locker' is the term used when a individual uses a welder to weld the spider gears together.
