Transbrake with Indy Crossram intake #731483
06/22/10 05:12 PM
06/22/10 05:12 PM
pa
K
Kyle Reasbeck Offline OP
K
pa
After getting a taste of transbraking it this weekend i'd like to use one on my 64 but am afraid of loading the indy crossram up with fuel vapors and blowing it sky high. Anybody transbraking with the indy crossram intake? What rpm are you leaving at?
Thanks!
Re: Transbrake with Indy Crossram intake [Re: Kyle Reasbeck] #731484
06/22/10 05:58 PM
06/22/10 05:58 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
If you do go that route I would use an air (co2)throttle - I would definitely not use two step with that intake. I have used the acd throttle control on a single four and it worked real good. I think i still have the air cylinder and a tank in the garage on the shelf. just checked still have - yours if you want it
Re: Transbrake with Indy Crossram intake [Re: Kyle Reasbeck] #731485
06/22/10 08:49 PM
06/22/10 08:49 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I've been running a brake with the Indy Crossram and two eldebrocks for a couple of years, never been a problem, but I've never had issues on start up that I've heard about either, mine starts up and idles real nice, it is better starting than my old original Max intake. I have a two step set at 3600 RPM, I don't stay on the two step very long, I floor it after my lights start coming down.
