Re: auto on the column levers the same from 6cyl to 8?
[Re: 79machocharger]
#73140
06/16/08 09:22 AM
06/16/08 09:22 AM
72 340 manifolds? The 72 book does not list a difference in the tube aasy (w-lever) 6-8 cyl at all.
#73142
06/16/08 09:36 AM
06/16/08 09:36 AM
I think you are into modification land, but if you say iy should work no problem, then bash away
#73145
06/16/08 10:24 AM
06/16/08 10:24 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Do you guys know if they make a cable set up, that hooks up to the column and tranny.
no , not that i have seen , a friend was looking for one at one time , shouldn't be too hard to do though
also again .... WHAT TRANSMISSION are you using ?
[Re: JohnRR]
#73146
06/16/08 10:45 AM
06/16/08 10:45 AM
Posts: 5,443 ME
79machocharger
ME
#73149
06/16/08 12:15 PM
06/16/08 12:15 PM
I do not see a different part for the linkage in the parts book, I think the problem lies with the earlier manifold.
