Budget 360 engine #731323
06/22/10 03:32 PM
06/22/10 03:32 PM
New York
jagrunt551 Offline OP
New York
I'm putting together a 360 (.030) over, flat top pistons, purpleshaft cam .484 lift. I got a good buy on some stock heads #3769974. These have 1.88/1.60 valves. Can I use these with that cam or do I need to have 2.02/1.60 valves? Also what would be a good intake manifold? Thanks
Re: Budget 360 engine [Re: jagrunt551] #731324
06/22/10 03:40 PM
06/22/10 03:40 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes ..you can use that cam with those heads....just check the exhaust valve to make sure they have regular retainers and not rotors...
ok...make sure the intake and exhaust retainers look alike...LOL
Tony
70 AARCuda Vitamin C
Re: Budget 360 engine [Re: 70AARcuda] #731325
06/22/10 04:18 PM
06/22/10 04:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
And make sure to use the valve springs that the cam calls for. Like said above make sure not to have rotators and if you do ditch them for 8 regular retainers to go with the correct springs.
the 1.88 valve heads will not hurt your performance a bit and may in fact give you better low end torque over the 2.02 heads.
Re: Budget 360 engine [Re: jagrunt551] #731326
06/22/10 04:30 PM
06/22/10 04:30 PM
scratchnfotraction Offline
what they said on the heads and retainers(if you need 8 more,give me a yell )
you will know the rotators when you see them,way diff than the intake retainers
it uses a shorter spring on the exhast valves
I would go with a LD340 or an airgap intake
my worthless
