Fuel pressure drops down track with elec. pump....... #730705
06/21/10 10:02 PM
06/21/10 10:02 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
I need some opinions on this one......
I noticed the other day that my fuel pressure gauge was down to 3lbs. of pressure from the 1/8 mile on. It's a Mallory pump, not sure which model cause of the way it's mounted in the car I can't see a number on it. It was all ready in the car when I got it. This is a "back up" car and I'm not pulling it apart unless I have to, lol.
The only thing I can think of that's causing this is because the gauge is tapped into the fuel line at the carb, not the regulator. At idle, and up to the 1/8, it's at 7lbs. Does this make sense, or could it be another problem?
Also, the car runs fine and pulls the whole way down the track. It doesn't act like it has low pressure, but the gauge is telling me it does.
Thanks in advance for any help!
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730706
06/21/10 10:18 PM
06/21/10 10:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
What size line. Remember that up to the 1/8 the engine is running freer and not pulling as hard as farther down track so will us less fuel and the pressure & supply will keep up easier that down track where the engine is working harder and using more fuel.
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730707
06/21/10 10:34 PM
06/21/10 10:34 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Many causes of this and not nearly enough information to make an educated guess.
Re: Fuel pressure drops down track with elec. pump....... [Re: MoparforLife] #730708
06/21/10 10:52 PM
06/21/10 10:52 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hmm
that is a interesting way of looking at it....Im not disagreeing with you, but one would think the car is accelerating less after the 8th mile point, usually gaining only 20-30 mph through the 2nd half of the track, meaning that the consumption of fuel after this point is really not increasing much.....
Next time your at the track, raise the float level about 1/2-3/4 turns out on the bowls, and increase fuel pressure to 8-8 1/2 lbs..see if the car responds with any increase in MPH....If it does, there might be a fuel starvation problem.
Re: Fuel pressure drops down track with elec. pump....... [Re: BobR] #730709
06/21/10 10:53 PM
06/21/10 10:53 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Sorry, long day..... It's a 3/8" fuel line from the tank to the carb. Mallory pump, Fram canister filter(new element), stock tank, 3/8" pick up, Holley reg., Holley 750, shift at 6,500. Anything else you need to know?
Re: Fuel pressure drops down track with elec. pump....... [Re: Bob_Coomer] #730710
06/21/10 10:59 PM
06/21/10 10:59 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Thanks Bob, I'll give that a shot.
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730711
06/21/10 11:02 PM
06/21/10 11:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1/2 fuel line and get rid of the fram fuel filter for a inline screen type fuel filter
1.39 9.85 - 137 mph
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730712
06/22/10 02:01 AM
06/22/10 02:01 AM
Fuel consumption is much greater in the last half of the 1/4 mile than the first 1/8 mile do to rpm acceleration per second, the first 1/8 you go through two or three gears, the last 1/8 is usually done in high gear only. The Fram canister can be a limiting factor on the supply side, check it to see if it is plug up full of trash or debris A friend of mine ended up substanially increasing his fuel volume by adding another Fram in parelel from the tank to the pump by adding a Y to the inlet side of the pump from the two filters If you can swing it use a better in line 40 micron or larger in line race fuel filter instead of one Fram or two Frams
Re: Fuel pressure drops down track with elec. pump....... [Re: Cab_Burge] #730713
06/22/10 07:10 AM
06/22/10 07:10 AM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Thanks for the idea's guys Not sure about the 1/2" fuel line right now. I should only be racing this thing for another month till my Valiants done.
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730714
06/22/10 07:24 AM
06/22/10 07:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Basically you could have a couple of issues.... If
the pressure held good before then its a pump MAYBE
going bad(doubt it) or the suction side cant supply
the pump with enough fuel
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730715
06/22/10 09:16 AM
06/22/10 09:16 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Is the stock sock in the tank? What model Mallory pump?
Re: Fuel pressure drops down track with elec. pump....... [Re: Cab_Burge] #730716
06/22/10 11:08 AM
06/22/10 11:08 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That be me and I picked up way more flow w/the two filters but I`d toss those and get something better and less restrictive. Yesturday I changed out my cannister filter and installed an Earls in line screen filter and my gauge read 1/2 lb. more pressure when I fired it up.
Re: Fuel pressure drops down track with elec. pump....... [Re: Thumperdart] #730717
06/22/10 12:13 PM
06/22/10 12:13 PM
Upper Midwest
Upper Midwest
Less restrictive will generally mean a more open filter with less filtering. Also remember more pressure doesn't always translate into more volume. In a carburated engine that doesn't require pressure to operate like injectors I prefer larger line size and more volume over higher pressure.
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730718
06/22/10 08:46 PM
06/22/10 08:46 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
Thanks again for the replies
Mr. P..... This car is fairly new to me, and I just noticed this issue last weekend. It may have happened before and I never noticed it.
BobR.... No idea if the sock is in the tank. I bought the car with this fuel system. I saw the car run 11.70's before I bought it and I "assumed" everything worked OK. The way the pump is mounted I can't read the model number. I'll try and remove it this weekend to verify.
drjay0...... That's how the pump is mounted. I know for a fact the car had 5 gallons of fuel that day. I don't think the pickup would become uncovered with that much fuel, but maybe it did.
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730719
06/22/10 09:42 PM
06/22/10 09:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think its time to pull the fuel system to check out
what you have and to correct where its not up to par
Re: Fuel pressure drops down track with elec. pump....... [Re: MR_P_BODY] #730720
06/22/10 09:57 PM
06/22/10 09:57 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
maybe even flow test it with a ball valve into a jug.
Re: Fuel pressure drops down track with elec. pump....... [Re: blownzoom440] #730721
06/23/10 01:03 AM
06/23/10 01:03 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
I know you have a stock tank.....my dads car this past weekend was shutting off down track.....around 1000'...he made 3 passes scratchin his head...tore the whole thing down sat night in the pits....nothing....then I said....you still got foam in this cell?...sure enough the foam had started coming apart and had plugged the outlet just enough that under full power it would run out of gas....
Took out the foam...good as new.....
Maybe there is a wayward piece of something in the tank?.....never know!
Re: Fuel pressure drops down track with elec. pump....... [Re: MR_P_BODY] #730722
06/23/10 10:33 PM
06/23/10 10:33 PM
Elbridge, NY
Dart1031 Offline OP
Dart1031  Offline OP
Elbridge, NY
All very good points! Unfortunatly I can't look into it until this weekend. Stinkin job gets in the way of my fun, lol.
Re: Fuel pressure drops down track with elec. pump....... [Re: Dart1031] #730723
06/24/10 12:04 AM
06/24/10 12:04 AM
Phoenix, Arizona
HerboldRacing Offline
Phoenix, Arizona
Replace the Fram filter with a Wix.
But really... why is 3 psi a problem? It is when it gets to 0 psi that your motor is consuming fuel faster than your pump can feed it. As long as it is above 0 you have fuel in your bowls. Is the engine missing at the top end?
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: Fuel pressure drops down track with elec. pump....... [Re: HerboldRacing] #730724
06/24/10 09:05 AM
06/24/10 09:05 AM
Az
Crizila Offline
Crizila  Offline
Az
Obviously, you wood like to see the pressure be the same throughout your 1/4 mile trip, but as long as the float bowls remain full, it won't make any difference if you have 4 lbs less in the lights. It does show that your existing system is "boarder line" though.
Fastest 300
