Re: Rings questions
[Re: dOoC]
#730680
06/22/10 05:53 PM
06/22/10 05:53 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
No hand hone can get it smooth enough. It's not a big deal.. The moly will just get scraped off and the rings will seat like normal rings. If the block was a running engine, I use green scotchbrite over the square stone flex-hone I have. Use WD40 for cutting oil, and dont go tto crazy. It's enough to take off the glaze but not to scar up the surface.
Re: Rings questions
[Re: way2fast]
#730683
06/22/10 09:41 PM
06/22/10 09:41 PM
moper
Columbia, CT
Use very thick oil to hone with. 320 is rough for a moly ring.
