R-block question #730587
06/21/10 06:18 PM
06/21/10 06:18 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
I need to know what oil pan and remain seal fit a r-block with 9.56 deck?
Re: R-block question [Re: demon454] #730588
06/21/10 07:00 PM
06/21/10 07:00 PM
408Dust Offline
408Dust  Offline
360 or 340 crank?
Block could have 360 or 340 rear cap,welcome to the wonderful world of R-blocks...
Re: R-block question [Re: demon454] #730589
06/21/10 07:00 PM
06/21/10 07:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think all R blocks use 360 pans(rear main wise)
Re: R-block question [Re: MR_P_BODY] #730590
06/21/10 07:46 PM
06/21/10 07:46 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
is it 2 piece rearmain
Re: R-block question [Re: demon454] #730591
06/21/10 07:51 PM
06/21/10 07:51 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
They can come EITHER WAY! It is totally RANDOM! It just happend to be whatever main caps they have on hand at the time. The caps can be machined either way as far as the mains and seal on the ID.
Unless this has changed with the new generation blocks. I reccomend you wait till you get the block to make sure.
SRT DEMON ONE SEAT
Re: R-block question [Re: MR_P_BODY] #730592
06/21/10 07:54 PM
06/21/10 07:54 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
My 501 is the 48 deg, tall deck, R3 and it is a 340 pan. Large radius at both ends. I do believe I have had them both ways. I have had to return pans before because of this issue.
SRT DEMON ONE SEAT
Re: R-block question [Re: Ron Silva] #730593
06/21/10 07:58 PM
06/21/10 07:58 PM
oregon
greendart408 Offline
oregon
My tall deck R block is 340 main with 360 pan. Like was said above though its seems random
Re: R-block question [Re: Ron Silva] #730594
06/21/10 08:00 PM
06/21/10 08:00 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
The reason in ask these questions is i just had my engine freshened and im ready to race then noticed a puddle on oil under car put it in the air and looked between bellhouseing and pan and saw it lightly spraying up near the rearmain/oilpan when running.doesnt leak when sitting and i have a race coming up need to fix asap and my engine builder is nowhere to be found so im in limbo of what seals in have.
Re: R-block question [Re: Ron Silva] #730595
06/21/10 08:01 PM
06/21/10 08:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My 9.2 deck 340 mains has a 360 pan
Re: R-block question [Re: MR_P_BODY] #730596
06/21/10 08:11 PM
06/21/10 08:11 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
so what do i do buy a 340 and 360 oil pan gasket and rearmain?
Re: R-block question [Re: demon454] #730597
06/21/10 08:17 PM
06/21/10 08:17 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
one of each and return the one you don't need.
Re: R-block question [Re: demon454] #730598
06/21/10 08:17 PM
06/21/10 08:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Measure across it
Re: R-block question [Re: MR_P_BODY] #730599
06/21/10 08:23 PM
06/21/10 08:23 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
sorry measure across what
Re: R-block question [Re: demon454] #730600
06/21/10 08:30 PM
06/21/10 08:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The main.... where the pan would sit
Re: R-block question [Re: MR_P_BODY] #730601
06/21/10 08:38 PM
06/21/10 08:38 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
ok will do that tomorrow what will it tell me
Re: R-block question [Re: demon454] #730602
06/21/10 10:12 PM
06/21/10 10:12 PM
Renton Washington
Triple Threat Offline
Renton Washington
Glad I read this, I assumed my R block used a 340 pan because it has 340 mains. I guess I'll go measure.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: R-block question [Re: Triple Threat] #730603
06/21/10 10:23 PM
06/21/10 10:23 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I have had several R blocks and looked at several dozen. Every one has been 360 pan except one. A little cutting in the mill and it was a 360 when done.
You can always run an adapter to use a 340 pan on a 360 cap.
Leon
