bondo in my Factory AAR hood? #730385
06/21/10 12:14 PM
06/21/10 12:14 PM
washington
67383scuda Offline OP
washington
--hey moparts--
0--i just got my original AAR hood in the mail and i see what appears to be a light skim coat of bondo around where the scoop rises vertically on the sides if that makes sense. the hood looks great on the underside. It appears to be good up top. i do notice a few layers of paint. my question is
--would plymouth EVER apply bondo to a fiberglass hood?
thanks moparts
Re: bondo in my Factory AAR hood? [Re: 67383scuda] #730386
06/21/10 02:03 PM
06/21/10 02:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The vendor that made the hood probably did that, or if someone repaired it subsequently.
Re: bondo in my Factory AAR hood? [Re: topside] #730387
06/21/10 02:36 PM
06/21/10 02:36 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I had 70 Challenger R/T dual scoop hood had that had bondo on the raised portion in it from the factory. So it could be possible.
Re: bondo in my Factory AAR hood? [Re: NV69B7RR] #730388
06/21/10 04:46 PM
06/21/10 04:46 PM
washington
washington
//thanks--
someone said they didnt have gel coat or something like that back in the 70's. so it may be possible --
there are no holes or chunks missing from the underside that i can see..
Re: bondo in my Factory AAR hood? [Re: 67383scuda] #730389
06/21/10 04:54 PM
06/21/10 04:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Gelcoat definitely existed in the '60s & '70s, and I'm sure way back to the early '50s. I was working with gelcoat and both hand-laid & chopper-gun fiberglass in '70 and it had been around awhile by then.
If there were voids in the 'glass, or cracks, or some modification to get the fit/finish better, the repairer would likely use body filler due to convenience and repair speed.
Re: bondo in my Factory AAR hood? [Re: topside] #730390
06/21/10 06:05 PM
06/21/10 06:05 PM
washington
washington
--thanks--
