0.5 or 3 ohm coil for Mopar Electronic Ign conversion #728871
06/20/10 09:53 AM
06/20/10 09:53 AM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
I have the Mopar electronic ignition conversion with orange ECU but don't know if it calls for a 1/2 ohm or 3 ohm coil. Anybody know for sure?
Thanks!
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversion [Re: T/A CARe] #728872
06/20/10 12:07 PM
06/20/10 12:07 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
do you mean the ballast resistor or the coil?.
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversion [Re: T/A CARe] #728873
06/20/10 02:00 PM
06/20/10 02:00 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Be certain to carry a spare ECU if you are running an orange box. Really need a spare for any ECU for that matter.
I want my fair share
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversion [Re: moparsquid] #728874
06/20/10 03:21 PM
06/20/10 03:21 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
The coil, or ultimately what the system calls for. The coil's resistance may be determined by the ballast resistor...
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversi [Re: T/A CARe] #728875
06/20/10 06:46 PM
06/20/10 06:46 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Why can't you run a coil that doesn't need a resistor.
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversi [Re: Todd] #728876
06/21/10 12:42 AM
06/21/10 12:42 AM
Not a direct answer but a particular ECU can only switch so much primary current which as you know is a combo of the coil pri + the ballast resistances. A 1.25 ohm ballast is supplied w the MP orange and chronme boxes and a .25 ohm ballast w the gold race box. Not sure what ohm coils are recommended
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversi [Re: RapidRobert] #728877
06/21/10 01:51 AM
06/21/10 01:51 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Is the orange box really that much of a turd?
I have read repeatedly that its reliability isn't good. I had a new one that failed early, but then again, I have had a few others that did too. Some factory originals I have had STILL work.
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversi [Re: Kern Dog] #728878
06/21/10 06:24 AM
06/21/10 06:24 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I believe the orange box and 1.25 ohm res is set up for stk ohms coils.Whatever that is I dont know.MSD whats you to use the mopar 1.25 and the msd .08 with the blaster.
Re: 0.5 or 3 ohm coil for Mopar Electronic Ign conversi [Re: Scamp408] #728879
06/21/10 07:46 AM
06/21/10 07:46 AM
Kansas
racincuda Offline
racincuda  Offline
Kansas
I have found that the Standard Motors LX101 to be a very reliable ecu and minimum of 1 ohm resistor was recomended for street use. i have found these easy to find , just check resistance with your meter, again I use the Standard Motors piece.
