Tranny troubles at the strip #728680
06/20/10 12:28 AM
06/20/10 12:28 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Went to the strip today not a good day. While doing a burn out in 2nd gear tires are spinning shift to 3rd tires stop spinning. Pull up to the lights luanch shift 1 to 2 and every thing is fine shift to 3rd and you can barely tell and my Rpm's only dropped a couple of 100's shift light hardly went off. Any idea's
Re: Tranny troubles at the strip [Re: flatiron] #728681
06/20/10 12:54 AM
06/20/10 12:54 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Do you still have reverse?
Re: Tranny troubles at the strip [Re: flatiron] #728682
06/20/10 12:54 AM
06/20/10 12:54 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
low fluid level ,
throttle preasure rod not correctly adjusted .
bad clucthpack
Re: Tranny troubles at the strip [Re: calrobb2000] #728683
06/20/10 12:58 AM
06/20/10 12:58 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Fluid level is good
I still have reverse
I forgot to mention that it is a full manuel reverse valve body, 5000 stall convertor flashed at about 3500, and started pushing while footbraking at about 2400
Also fluid in tranny looks and smells good.
Re: Tranny troubles at the strip [Re: flatiron] #728684
06/20/10 01:10 AM
06/20/10 01:10 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
im having similar problems = join the club.
what valve body do you have ?
Re: Tranny troubles at the strip [Re: flatiron] #728685
06/20/10 01:22 AM
06/20/10 01:22 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
long ago i had a transmission pretty much the same thing and i found out i smoked something in the converter.mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Tranny troubles at the strip [Re: 493_DART] #728686
06/20/10 02:00 AM
06/20/10 02:00 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Cheetah
Re: Tranny troubles at the strip [Re: flatiron] #728687
06/20/10 10:42 AM
06/20/10 10:42 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Re: Tranny troubles at the strip [Re: flatiron] #728688
06/20/10 10:57 AM
06/20/10 10:57 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I had a similar prob years ago, i pulled that tranny 5-6 times and went through it and could never find anything wrong, then i started combing for any signs of a cause and i found the shift cable slightly out of adjustment going from 2-3rd, 1 or 2 turn adjustment and it was all good, go through each shift while the car is on jacks (engine off) and remove the cable from the lever and see if its clicking into each shift just right,
