which bands and clutches for aluminum drum #728180
06/19/10 05:13 PM
06/19/10 05:13 PM
Nazareth,Pa.
JACKSON Offline OP
JACKSON  Offline OP
Nazareth,Pa.
putting together and rebuilding a 727 torqueflite and have a a & a aluminum drum,
which cluthes and bands do you recommend to use with an aluminum drum?
dont want that silvery metal in my trans. fluid anymore. JACKSON
Re: which bands and clutches for aluminum drum [Re: JACKSON] #728181
06/19/10 06:25 PM
06/19/10 06:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: which bands and clutches for aluminum drum [Re: JACKSON] #728182
06/19/10 08:41 PM
06/19/10 08:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Use a Kevlar band and you'll have more than silvery fluid, It will look like the drum has been on a lathe. Don't ask how I know.
Doug
Re: which bands and clutches for aluminum drum [Re: dvw] #728183
06/19/10 10:12 PM
06/19/10 10:12 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Red Racing Bands, Alto Red Eagle frictions are what I am using
Alan Jones
Re: which bands and clutches for aluminum drum [Re: LA360] #728184
06/19/10 10:20 PM
06/19/10 10:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
with an aluminum drum make sure the band does not have any grooves in the lining
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: which bands and clutches for aluminum drum [Re: JACKSON] #728185
06/19/10 10:57 PM
06/19/10 10:57 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Call Rick @ A&A and get the parts from him.Tell him what you are running and he will set you up with the right parts.He is a top notch guy.
I just bought new Red Alto frictions,kolene steels,and a red lined solid band for my aluminum drum from him.
Re: which bands and clutches for aluminum drum [Re: JACKSON] #728186
06/20/10 09:04 AM
06/20/10 09:04 AM
NC
440Jim Offline
440Jim  Offline
NC
With an aluminum drum, use a red lined band (I prefer solid band, not flex), and make sure the one you buy has no grooves in the lining. Smooth lining for aluminum surface.
For the clutch pack, the drum material isn't a factor, get the ones that fit your application. The Alto Red Eagle clutches are very good, but you may not need to spend that much. Same with the Kolene steels.
Re: which bands and clutches for aluminum drum [Re: 440Jim] #728187
06/20/10 10:56 AM
06/20/10 10:56 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I prefer stock style waffle clutches over the smooth more expensive red ones. A clutch pack slips when you apply it. Run the smooth clutches and they do the same thing slicks would on a wet road. They float and delay application. I tried stock replacements as well as the ALTO reds. My best luck was with the blue ones with the cross cuts commonly called waffle cut. There is less contact between clutch and steel which some think outweighs the possibility to slip on application. I ran a huge amount of power on four blue waffle clutches and the pack lasted well through the season.
Sense switching to a powerglide I've noticed the 8 pack clutch that everyone wants is the same blue waffle clutch. When you service the tranny the first thing you notice is no black grit in the clutch hub. That's because there is less slip on application and the junk is washed out by design.
Just My Opinion
Leon
