I have a real bad oil leak in my smallblock.
After a couple minutes, it comes pouring out from the top of the back of the engine.
I haven't been able to look good enough back there. All I can think of it a bad intake manifold gasket, ot something at the oil pressure switch fitting.
Also, if I overfilled the pan by 2 quarts, would that do any damage. I don't remember how much oil I put in last time. I put in 2 jugs. so it was either 8 or 10 quarts. I have a deep moroso pan on it.
I been diagnosing the leak and I changed i've had the filter off twice and this last time a new filter. (i originally thought the leak was the filter housing gasket) and the level is not 1/4 below the full mark on the dipstick. So now I'm wondering if I threw 10 quarts in and it's an 8 quart pan. I didn't buy the pan, it was on the car, so I'm not 100% sure how much it holds.
Any suggestions.
Thanks,
Nick
![](/ubbthreads/images/graemlins/smilie_help.gif)
