motors out #728123
06/19/10 03:15 PM
06/19/10 03:15 PM
Kissimmee Fl.
dusturbd340W5 Offline OP
Kissimmee Fl.
what do you think about the color of these exhaust ports motor was running fine just doing a cam swap and installing new Harlan Sharp rockers and my cut the heads for more squeze
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: motors uot [Re: dusturbd340W5] #728124
06/19/10 03:16 PM
06/19/10 03:16 PM
Kissimmee Fl.
Kissimmee Fl.
1 more they all look the same
Re: motors out [Re: dusturbd340W5] #728125
06/19/10 04:29 PM
06/19/10 04:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
looks good to me. is that oil leaking on the valve stem?
Re: motors out [Re: Quicktree] #728126
06/19/10 07:38 PM
06/19/10 07:38 PM
408Dust Offline
408Dust  Offline
Could not resist could you, little oil leaking on the exhaust valves is not a problem its going out not in.
Attention DC426 trouble coming your way!!!
Re: motors out [Re: 408Dust] #728127
06/19/10 08:41 PM
06/19/10 08:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats true but if it's leaking on the exhaust it's possible to be leaking on the intake. which could cause problems.
Re: motors out [Re: Quicktree] #728128
06/19/10 10:18 PM
06/19/10 10:18 PM
Kissimmee Fl.
Kissimmee Fl.
no I couldn't I figured what the he!! might as well go for broke.
the motor was still warm when those pictures where taken and that is the only 1 that is like that I am not going to worry about it.
I just came in and got a shower I have the heads off and the pan and timing cover off I clayed 5 cylinder's for dome to chamber clearence.
I will try to get the new cam in and degreed Sunday and check PV clearence so I can get the heads stripped down and get them to the machine shop to get cut.
Re: motors out [Re: dusturbd340W5] #728129
06/19/10 11:15 PM
06/19/10 11:15 PM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
who's gonna do the head work?
Re: motors out [Re: dc426] #728130
06/19/10 11:19 PM
06/19/10 11:19 PM
Kissimmee Fl.
Kissimmee Fl.
Kevin
Re: motors out [Re: dusturbd340W5] #728131
06/19/10 11:21 PM
06/19/10 11:21 PM
Tampa Florida
dc426 Offline
dc426  Offline
Tampa Florida
good choice
