What is a good Body Filler? #72758
06/13/08 12:12 AM
06/13/08 12:12 AM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
What is the best brand of body filler to use?
Re: What is a good Body Filler? [Re: 71Polara383] #72759
06/13/08 12:20 AM
06/13/08 12:20 AM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
Hammer and a dolly and or a welder and some clean metal.
Then I seem to use the PPG related items. NO BONDO brands at all. It all depends on the depth and type of use.
Re: What is a good Body Filler? [Re: RUMBLON] #72760
06/13/08 12:43 AM
06/13/08 12:43 AM
Southern Calif. somewhere
NigelTufnel Offline
NigelTufnel  Offline
Pretty happy with Evercoats 'Rage gold'. Any good autobody supply will have it. Also try to get the green plastic spreaders, they're a little 'stiffer' and in my opinion better.
hope that helps
Re: What is a good Body Filler? [Re: NigelTufnel] #72761
06/13/08 01:16 AM
06/13/08 01:16 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
hope that helps
Rage is good stuff.
Bondo being used in this case as a generic term, much like Kleenex, I expect.
So what's a good PPG body filler?
Re: What is a good Body Filler? [Re: RobX4406] #72762
06/13/08 01:29 AM
06/13/08 01:29 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
back in my auto-body course in college, we used a filler called 'Dyna-lite' "with space-age micro spheres" it must have been the high tech of the time! this was 1989...
Re: What is a good Body Filler? [Re: 71Polara383] #72763
06/13/08 01:32 AM
06/13/08 01:32 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used some bondo brand filler on my brother's rampage. Seems to work fine.
Re: What is a good Body Filler? [Re: NigelTufnel] #72764
06/13/08 01:51 AM
06/13/08 01:51 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Agreed on the Rage Gold,I use it on any motorcycle sheet metal requiring filler at my shop.Shapes and sands easily with 80 grit(shape as much as you can before it dries!).Few if any pinholes to glaze,shrinkage seems to be minimum.Make sure you use a good catalyzed primer over the filer.I use House of Kolor or PPG primers to be used with their respective topcoats.There are many good primers out there,but I like to use the same product brand start to finish.Using one manufacturers product(prime to paint)will greatly reduce any problems due to any incompatible chemical makeup.-Ron
see some paint examples on my site: www.northhillscycle.com
Re: What is a good Body Filler? [Re: RTSrunner] #72765
06/13/08 03:28 AM
06/13/08 03:28 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Prime Rib and Twinkies!
Re: What is a good Body Filler? [Re: RTSrunner] #72766
06/13/08 07:22 AM
06/13/08 07:22 AM
Rage gold is my preference,but theres also dynatron which is is sold at autozone or advance i can,t remember which but it almost the same as rage gold but cheaper it works great.
Re: What is a good Body Filler? #72767
06/13/08 09:22 AM
06/13/08 09:22 AM
rage gold.
Re: What is a good Body Filler? [Re: 71Polara383] #72768
06/13/08 12:39 PM
06/13/08 12:39 PM
Evercoat Z-grip
Re: What is a good Body Filler? [Re: migsBIG] #72769
06/13/08 01:05 PM
06/13/08 01:05 PM
O
OLD318 Offline
OLD318  Offline
O
Amen!
Re: What is a good Body Filler? [Re: 71Polara383] #72770
06/13/08 03:59 PM
06/13/08 03:59 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I've used All Metal with good results and also
Por-15 makes some really, really good fillers.
they cost a pretty penny but are worth it.
Re: What is a good Body Filler? [Re: 71Polara383] #72771
06/13/08 09:58 PM
06/13/08 09:58 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
I've used Marson Platinum for the last 6-7 years with very good results. Rage Gold is another excellent filler. I only stopped using Rage because if it sat unused in the can for very long, the resin would seperate (rise) from the filler itself. In hot enviroments this would cause a dark crust-like material to form on the top edge. I don't want junk mixing in with my filler, so I quit using it.
Steve
www.clarkclassic.com
Re: What is a good Body Filler? [Re: BarrsRestoration] #72772
06/13/08 10:15 PM
06/13/08 10:15 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Evercoat Rage Gold Coat is very good filler. I defintely aree on that one.
Re: What is a good Body Filler? [Re: gomangoRTSE] #72773
06/13/08 11:24 PM
06/13/08 11:24 PM
PA--USA
70VERT Offline
70VERT  Offline
PA--USA
I hate to pile on here but.......I wouldn't use anything BUT Rage Gold. Excellent adherence and super easy to sand and shape
