Re: What is a good Body Filler?
[Re: NigelTufnel]
#72761
06/13/08 01:16 AM
06/13/08 01:16 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Pretty happy with Evercoats 'Rage gold'. Any good autobody supply will have it. Also try to get the green plastic spreaders, they're a little 'stiffer' and in my opinion better.
hope that helps
Rage is good stuff.
Bondo being used in this case as a generic term, much like Kleenex, I expect.
So what's a good PPG body filler?
[Re: NigelTufnel]
#72764
06/13/08 01:51 AM
06/13/08 01:51 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Agreed on the Rage Gold,I use it on any motorcycle sheet metal requiring filler at my shop.Shapes and sands easily with 80 grit(shape as much as you can before it dries!).Few if any pinholes to glaze,shrinkage seems to be minimum.Make sure you use a good catalyzed primer over the filer.I use House of Kolor or PPG primers to be used with their respective topcoats.There are many good primers out there,but I like to use the same product brand start to finish.Using one manufacturers product(prime to paint)will greatly reduce any problems due to any incompatible chemical makeup.-Ron see some paint examples on my site: www.northhillscycle.com
[Re: RTSrunner]
#72766
06/13/08 07:22 AM
06/13/08 07:22 AM
#72767
06/13/08 09:22 AM
06/13/08 09:22 AM
[Re: 71Polara383]
#72768
06/13/08 12:39 PM
06/13/08 12:39 PM
[Re: migsBIG]
#72769
06/13/08 01:05 PM
06/13/08 01:05 PM
OLD318
Prime Rib and Twinkies!
Amen!
[Re: 71Polara383]
#72771
06/13/08 09:58 PM
06/13/08 09:58 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
I've used Marson Platinum for the last 6-7 years with very good results. Rage Gold is another excellent filler. I only stopped using Rage because if it sat unused in the can for very long, the resin would seperate (rise) from the filler itself. In hot enviroments this would cause a dark crust-like material to form on the top edge. I don't want junk mixing in with my filler, so I quit using it. Steve www.clarkclassic.com
