So I'm peicing together this 440 for my car, and along with that am using an aftermarket aluminum water pump housing. I got an aftermarket OEM-type replacement temp sender that's fairly thin with fine threads on it, but the w/pump housing on the driver's side has an even smaller hole in it with fine threads.. [Edited by Moparts - Family Friendly Site - Keep it clean]?
And on the heater hose side of the housing, it's got 3 holes.
Does a different style sender exist for the passenger side of the housing? I am running rally guages in the car..
![](/ubbthreads/images/graemlins/shruggy.gif)
