holley double pumper question #727275
06/18/10 04:03 AM
06/18/10 04:03 AM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
will 750cfm metering blocks work on a 850cfm carb?
what i want to do is buy the billet 850cfm body and base plate and use my 750cfm dp for parts. is this okay or am in for trouble when it comes to tune???
thanks
Re: holley double pumper question [Re: dirtycj5] #727276
06/18/10 08:22 AM
06/18/10 08:22 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
The primary block should be fine, but you'll have to make sure the secondary block has idle mixture screws if you want to take advantage of 4-corner idle. (Assuming the billet baseplate is set up for 4-corner idle.)
