Hazard light not working -- electrical help needed!! #727081
06/17/10 09:20 PM
06/17/10 09:20 PM
PA - Phila
71GRANCOUPE Offline OP
PA - Phila
I am working on a 68 Barracuda. The Hazard lights work fine except for the drivers side light. I have changed the bulb (2x) and have now come to the realization that it must be a wire for that lamp.
The lamp is the parking light, turn signal, and the flasher. The turn signal works -- so does the parking light but the flasher will not work. Is it a seperate connection?
Where should I begin to fix this problem? Any help would be appreciated.
68 Barracuda Conv
Re: Hazard light not working -- electrical help needed!! [Re: 71GRANCOUPE] #727082
06/19/10 06:05 PM
06/19/10 06:05 PM
under the hood
A47 Offline
A47  Offline
under the hood
mine had had the same sort of problem , dirt inside the switch , took mine apart & clean it , light dab of deelectrical grease , worked like new
but also check & clean all ground wires as a grounding problem can cause all sorts of odd things happening
