Thickness of timing chain sprocket? #727075
06/17/10 09:15 PM
06/17/10 09:15 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Can someone please give me the thickness of a BB timing chain crank sprocket.
I'm installing a gear drive and need to figure if I need to add a spacer to move the damper out or if the gear drive sprocket is thicker for that purpose. Thanks in advance.
Re: Thickness of timing chain sprocket? [Re: Stanton] #727076
06/18/10 12:25 PM
06/18/10 12:25 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
bump
Anyone ???
Re: Thickness of timing chain sprocket? [Re: Stanton] #727077
06/18/10 02:08 PM
06/18/10 02:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
What gear drive are you using?We did the PJ in my kis 62 413 and the gear on the crank was fine.Rocky
Chrysler Firepower
Re: Thickness of timing chain sprocket? [Re: therocks] #727078
06/18/10 09:36 PM
06/18/10 09:36 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Yeah, that's because the PJ unit uses a double idler. Mine is an older Milodon and everything is on a plate that moves the timing cover out 1/8". Subsequently the damper has to move also.
So back to my original question ...
