Re: redrilling leaf springs?
[Re: 65rbdodge]
#726676
06/17/10 08:44 PM
06/17/10 08:44 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I don't think thats going to work, first drilling the springs won't be easy, second , 8" back would screw up the way the spring is made to work. Maybe you should look for a shorter spring, redo the mounts farther back, Maybe coil over shock set up?
[Re: 65rbdodge]
#726678
06/17/10 11:41 PM
06/17/10 11:41 PM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
it needs to go back about 8" they are early b-body springs i`m putting in a 47 desoto.
If the front segment is 8" too long, is the back long or short? If you can, I'd move the spring forward in the car instead of re-drilling the center pin hole. 8" is a long way to move that center bolt. I too would have to wonder how the spring is going to work, unless your just drilling the main leaf and repositioning the rest of the springs to the new center pin location. Going to take a real good drill bit, lots of cutting oil, and a slow turning drill motor to drill that main leaf. then start small and work your way up to size. Cutting leaf springs is no picnic either. Gene
[Re: 65rbdodge]
#726680
06/20/10 01:53 AM
06/20/10 01:53 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
posies rod shop in hummelstown pa probably has leafs for that car,, under his super slide program,,if he has them which im sure he does,,they will bolt right in your stock location,and lower the car almost 2 inches,then he has or can get you shocks made to work with those springs that bilstein make, i have that set up in my 40 dodge,,and the leafs that were in my 40 dodge are now in a 48 dodge ,ide assume same springs in ur 47 desoto,,
also you can get springs at any local spring shop,,,or from EATON,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
