which 8.75" rear in 47 desoto? #726661
06/17/10 01:54 PM
06/17/10 01:54 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i`m trying to put an 8.75 in my 47 desoto. i have a 65 b-body and 69 b-body 8.75" they are both narrower than the rear that came in the desoto. the 69 is only about 1" narrower than the desoto rear. i want to use 15x7 police wheels. with the original rear, wheels and skinny bias ply tires there was only about 1.5" between the tire and frame. i can get a 68 c-body 8.75 which i`m sure is wider than the 69b-body. should i get it and see if it works? what have others used?
Re: which 8.75" rear in 47 desoto? [Re: 65rbdodge] #726662
06/17/10 03:52 PM
06/17/10 03:52 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
An E-Body rear was an exact bolt-in in the 55 Desoto that I'm building for Kayse.
The spring perches were the correct width (46) and the overall width was within a 1/4 inch.
Re: which 8.75" rear in 47 desoto? [Re: SNK-EYZ] #726663
06/17/10 08:47 PM
06/17/10 08:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'd get a tape measure out myself. That's how I found out the 9 1/4 out of a 79 Newport it my 38 Plymouth.
But that's just me.
Don't be the exception.
Re: which 8.75" rear in 47 desoto? [Re: 65rbdodge] #726664
06/17/10 11:27 PM
06/17/10 11:27 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If the rear end you have is only 1" narrower then what was there, and you did have 1 1/2" per side clearance, you should be OK, you will still have 1" clearance. I've run cars with a lot less then that without issues. Gene
Re: which 8.75" rear in 47 desoto? [Re: poorboy] #726665
06/18/10 08:18 PM
06/18/10 08:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think you missed the part about the 1 1/2" of clearance being with the original style BIAS PLY skinnies on it, not the bigger rims he wants to run.
Re: which 8.75" rear in 47 desoto? [Re: Supercuda] #726666
06/18/10 11:49 PM
06/18/10 11:49 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, missed that. Sorry. Gene
Re: which 8.75" rear in 47 desoto? [Re: poorboy] #726667
06/20/10 01:39 PM
06/20/10 01:39 PM
n.e. pa.
n.e. pa.
after measuting it looks like a truck rear will work. i found a 9.25 in a 78 ramcharger, 355`s and a 4.5"bp just what i need.
Re: which 8.75" rear in 47 desoto? [Re: 65rbdodge] #726668
06/20/10 07:56 PM
06/20/10 07:56 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
I run C-body 8 3/4 in my 47 plymouth fits well with 275 60 15 on 15x8.
mike
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: which 8.75" rear in 47 desoto? [Re: 65rbdodge] #726669
11/15/11 10:52 PM
11/15/11 10:52 PM
Middlesboro, Ky.
hemi62valiant Offline
Middlesboro, Ky.
did you end up putting a truck 8 3/4 in your Desoto? I have a '55 and a truck rear end..numbers look right...just curious how yours looked with tires in place
Eddie Walker
Re: which 8.75" rear in 47 desoto? [Re: hemi62valiant] #726670
11/16/11 12:37 AM
11/16/11 12:37 AM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
I run a 68 b body 8.75 in my 48 plym ,with a 15×8 wheel 4.25 bs 255/70/15 tires. You might be able to squeeze a finger between fender lip and frame rail on inside. I used straight edges and measured out for back space fitment in wheel well.
48 plymouth 2 door sedan street rod
65 meyers manx dune buggy
66 coronet 500 (resto project)
77 w200 m880
02 dakota
Re: which 8.75" rear in 47 desoto? [Re: 66cnet500] #726671
11/17/11 04:11 PM
11/17/11 04:11 PM
n.e. pa.
n.e. pa.
well i have the 9.25" ramcharger rear sitting in there now but got an 8.75 out of a 68 fury from the local u-pullit last week for $45 so i`m gonna use it with some 3.23`s i have. i don`t really care for the 9.25"`s axel bearing design, i`ve had problems with them in the past.
Re: which 8.75" rear in 47 desoto? [Re: 65rbdodge] #726672
11/17/11 11:30 PM
11/17/11 11:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
find a 8 3/4 from a 72/74 pickup. They are a little wider than the pre 72. It is the same dimention as the 9 1/4...
I am truckless..
