Victor 340 vs. RPM Air Gap on a 408 #726544
06/17/10 12:07 PM
06/17/10 12:07 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
Anyone have any comparisons ? I know the Super Victor doesnt do as well, but I'm talking about the ole Victor 340. This would be on a street 408, with RHS heads , hydraulic cam engine.
Thanks for the replies.
J.C. Childress (434) 665-9541
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: JC Childress] #726545
06/17/10 02:52 PM
06/17/10 02:52 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I will have a comparison in ~30 days. I currently run an Airgap, and I’m buying a Victor next week. My next race is July 17th….so, it might be hard to make a good comparison if the air is hot and humid. I’ll post the results when I run it.
I’m not much help now, but here’s a
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: FlyFish] #726546
06/17/10 03:41 PM
06/17/10 03:41 PM
Big Island ,VA
Big Island ,VA
Whats your current combo , as far as heads, comp ratio and camshaft ?
Thanks for the reply
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: JC Childress] #726547
06/17/10 03:57 PM
06/17/10 03:57 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
410, ported eddys, 10.8:1 comp, pump gas, small solid roller (248/254, .576/.582), Air-gap, 750dp, 8” PTC vert, 4.10 gear.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: FlyFish] #726548
06/17/10 04:02 PM
06/17/10 04:02 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I like the Victor
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: JC Childress] #726549
06/17/10 04:07 PM
06/17/10 04:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For a street car you would be better with the air gap
cause you would be spending most of the time in lower
rpms
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: Scamp408] #726550
06/17/10 11:39 PM
06/17/10 11:39 PM
Az
Crizila Offline
Crizila  Offline
Az
I like the Victor
Me too. IMO, it will out perform the Air Gap on a 408 in almost every instance. I run a slightly modified 340 with a 1" spacer on a moderate 408 in a very heavy car with no problems.
Fastest 300
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: Crizila] #726551
06/18/10 07:06 AM
06/18/10 07:06 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
We also had the older Victor on our 416 pump gas bracket motor, also with a .560" cam, and that worked super well with awesome bottom end and really great mid range. The upper end wasn't so good, but we had nearly stock heads on it, and it would fall off in the upper ranges. Based on my experience with the AG on my 360, the AG would be a restriction on the larger motors.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: JC Childress] #726552
06/18/10 10:38 AM
06/18/10 10:38 AM
AndyF Offline
AndyF  Offline
I'd run the RPM intake on the street, especially with a hyd cam. If you take both intakes to a chassis dyno session you'll see that the RPM will make more power all the way up to at least 5000 rpm. Keep your eye on the tach as you drive around town and I bet you rarely spin the motor past 5000 rpm.
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: AndyF] #726553
06/18/10 08:42 PM
06/18/10 08:42 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I was also wondering if this would be a good move as I now run the air gap. So a couple years ago I asked some Edelbrock reps and they said that the air gap was/is made off the same principle as the victor and that the change would be very minute and wouldnt warrant spending the extra money for the victor. I even told them I could have gotten a new one from a friend for $100 he wasnt using and they still said dont waste the money. Now maybe a nice big stroker with a serious cam and head work might benefit from the victor but who knows without some dyno time.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: G-Money1320] #726554
06/18/10 11:51 PM
06/18/10 11:51 PM
Az
Crizila Offline
Crizila  Offline
Az
Totally different manifolds. I have run them both on my 408, and if you are running a decent flowing pair of heads and a cam in the 250* / .600" range, the 340 will beat the air gap at any rpm. Trust me, I'm a mechanic
Fastest 300
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: Crizila] #726555
06/19/10 02:44 AM
06/19/10 02:44 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Not to be a fanboi of other folks cars or speak for them, but (in addition to crizila's big 300) a good car that defies logic is qwkmopardan's 4100lb 1979 300.
He is running a single plane intake and a big cam in a very heavy car street car.
- Victor 340 intake on his pump-gas 408 with a 262 @.050 flat tappet cam.
- Runs 11.60's.
- Ported junkyard 587 iron heads, too...
qwkmopardan
This one is a 408 with similar heads as the Demon but car weighs Over 4100lbs and has a full exh with 4 mufflers. Cam has only .527 lift and 262 at .050. It has near 15000 miles on it now and still going strong. Best 1/4 mile pass on this car is 11.600 at 116mph. ... cars have nicely ported Victor 340 intakes. The "300" has a 9" J converter
Although most folks would initially recommend a RPM Air Gap and a much smaller cam profile for this plus-sized car.
...Dan sure seems to run just dandy with the victor 340 and healthy cam, though.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: topbrent] #726556
07/19/10 08:36 AM
07/19/10 08:36 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
***UPDATE***
Got a chance to run my car with the Victor intake (see 2nd & 4th post on this thread)…looks like I paid good money to slow the car down. The car was running 7.08 in the heat with tire spinning 60’ time in the 1.55’s. I now have new tires and the Victor intake on and the car ran 7.16 in the heat with a dead hook 60’ of 1.59. The car won’t pull the front end off the ground anymore…definitely lost a lot of torque…the converter was flashing to ~5100 now its ~ 4800. I tried many different shift points over the course of 2 days and it ran the fastest when I wound it up to 6500 on every shift. With the Air-gap it ran faster shifting @ ~6000. I will be switching back to the Air-gap when time permits and keeping the Victor for future upgrades.
So, at least for my combo, the Victor was not the better intake.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: FlyFish] #726557
07/19/10 08:40 AM
07/19/10 08:40 AM
NY usa
540challenger Offline
NY usa
***UPDATE***
great info, Thanks for taking your time to post.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: 540challenger] #726558
07/19/10 08:49 AM
07/19/10 08:49 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
***UPDATE***
The intake was all that you changed? I would assume that some carb tuning and / or timing adjustments would be in store after the swap.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Victor 340 vs. RPM Air Gap on a 408 [Re: JC Childress] #726559
07/19/10 08:54 AM
07/19/10 08:54 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have both and can say the Victor 340 is heads above the RPM manifold.
My Victor equipped 340 with Eldebrock heads runs way better than it did with the RPM manifold. I did real world testing where I changed it out in my driveway and drove both the same day, same motor same carb.
There's plenty of bottem end torque for me and runs my AC non stop during the summer. I've driven my 340 at least 3000 miles this summer alone. She screams and barks the tires harshly, was not that aggresive with the RPM manifold.
With a 408, I'd have to say the RPM would get beat all to heck by the Victor.
Checkout this threead from last week: web page
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: bigsbigelow] #726560
07/19/10 10:01 AM
07/19/10 10:01 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
***UPDATE***
I also put on new tires because the old ones were DEAD...same size and type as before (28x11.5 Hoosier QTP)
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: FlyFish] #726561
07/19/10 10:06 AM
07/19/10 10:06 AM
Cincinnati, Ohio
Cincinnati, Ohio
***UPDATE***
What was the density alitiude on the before and after runs?
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: Challenger 1] #726562
07/19/10 11:04 AM
07/19/10 11:04 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
One of the guys near my pit said the DA was ~ 4000 feet (about 92° F). The previous run was the same temp, but I don't know what the DA was. What I do know is with the old intake the worst 60’ times ever were 1.56-1.57, on “normal” hot summer days it would run 1.53’s. Also, the MPH was close to normal…down just a little. Normal in the heat, ~96.0-96.5…with the Victor it ran 95.6-95.9.
I think with a bigger cam, this intake would be great, but apparently my cam is just a little too small….or if I was running ¼ mile it would probably be faster since I would be spending more time above 6000 RPM…just thinking out loud.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE**** [Re: Challenger 1] #726563
07/19/10 11:18 AM
07/19/10 11:18 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I would think for the victor to prove its self you would need to turn to @ least 7k, If your heads and cam an support the RPM, The air gap is a over all grate intake but usually wont go past 6500
