Victor 340 vs. RPM Air Gap on a 408
#726544
06/17/10 12:07 PM
06/17/10 12:07 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
Anyone have any comparisons ? I know the Super Victor doesnt do as well, but I'm talking about the ole Victor 340. This would be on a street 408, with RHS heads , hydraulic cam engine.
Thanks for the replies.
J.C. Childress
(434) 665-9541
Re: Victor 340 vs. RPM Air Gap on a 408
[Re: JC Childress]
#726545
06/17/10 02:52 PM
06/17/10 02:52 PM
Posts: 1,178 Indy
FlyFish
Indy
I will have a comparison in ~30 days. I currently run an Airgap, and I’m buying a Victor next week. My next race is July 17th….so, it might be hard to make a good comparison if the air is hot and humid. I’ll post the results when I run it. I’m not much help now, but here’s a
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#726546
06/17/10 03:41 PM
06/17/10 03:41 PM
JC Childress
Big Island ,VA
Whats your current combo , as far as heads, comp ratio and camshaft ?
Thanks for the reply
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#726547
06/17/10 03:57 PM
06/17/10 03:57 PM
Posts: 1,178 Indy
FlyFish
Indy
410, ported eddys, 10.8:1 comp, pump gas, small solid roller (248/254, .576/.582), Air-gap, 750dp, 8” PTC vert, 4.10 gear.
[Re: Crizila]
#726551
06/18/10 07:06 AM
06/18/10 07:06 AM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
We also had the older Victor on our 416 pump gas bracket motor, also with a .560" cam, and that worked super well with awesome bottom end and really great mid range. The upper end wasn't so good, but we had nearly stock heads on it, and it would fall off in the upper ranges. Based on my experience with the AG on my 360, the AG would be a restriction on the larger motors.
[Re: Crizila]
#726555
06/19/10 02:44 AM
06/19/10 02:44 AM
Posts: 793 Utah
topbrent
Utah
Not to be a fanboi of other folks cars or speak for them, but (in addition to crizila's big 300) a good car that defies logic is qwkmopardan's 4100lb 1979 300. He is running a single plane intake and a big cam in a very heavy car street car. - Victor 340 intake on his pump-gas 408 with a 262 @.050 flat tappet cam. - Runs 11.60's. - Ported junkyard 587 iron heads, too... Quote:
qwkmopardan This one is a 408 with similar heads as the Demon but car weighs Over 4100lbs and has a full exh with 4 mufflers. Cam has only .527 lift and 262 at .050. It has near 15000 miles on it now and still going strong. Best 1/4 mile pass on this car is 11.600 at 116mph. ... cars have nicely ported Victor 340 intakes. The "300" has a 9" J converter
Although most folks would initially recommend a RPM Air Gap and a much smaller cam profile for this plus-sized car. ...Dan sure seems to run just dandy with the victor 340 and healthy cam, though.
Re: Victor 340 vs. RPM Air Gap on a 408****UPDATE****
[Re: FlyFish]
#726557
07/19/10 08:40 AM
07/19/10 08:40 AM
Posts: 2,826 NY usa
540challenger
NY usa
***UPDATE***
Got a chance to run my car with the Victor intake (see 2nd & 4th post on this thread)…looks like I paid good money to slow the car down. The car was running 7.08 in the heat with tire spinning 60’ time in the 1.55’s. I now have new tires and the Victor intake on and the car ran 7.16 in the heat with a dead hook 60’ of 1.59. The car won’t pull the front end off the ground anymore…definitely lost a lot of torque…the converter was flashing to ~5100 now its ~ 4800. I tried many different shift points over the course of 2 days and it ran the fastest when I wound it up to 6500 on every shift. With the Air-gap it ran faster shifting @ ~6000. I will be switching back to the Air-gap when time permits and keeping the Victor for future upgrades.
So, at least for my combo, the Victor was not the better intake.
great info, Thanks for taking your time to post.
[Re: 540challenger]
#726558
07/19/10 08:49 AM
07/19/10 08:49 AM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
***UPDATE***
The intake was all that you changed? I would assume that some carb tuning and / or timing adjustments would be in store after the swap.
[Re: JC Childress]
#726559
07/19/10 08:54 AM
07/19/10 08:54 AM
Challenger 1
Cincinnati, Ohio
I have both and can say the Victor 340 is heads above the RPM manifold. My Victor equipped 340 with Eldebrock heads runs way better than it did with the RPM manifold. I did real world testing where I changed it out in my driveway and drove both the same day, same motor same carb. There's plenty of bottem end torque for me and runs my AC non stop during the summer. I've driven my 340 at least 3000 miles this summer alone. She screams and barks the tires harshly, was not that aggresive with the RPM manifold. With a 408, I'd have to say the RPM would get beat all to heck by the Victor. Checkout this threead from last week: web page
[Re: bigsbigelow]
#726560
07/19/10 10:01 AM
07/19/10 10:01 AM
Posts: 1,178 Indy
FlyFish
Indy
***UPDATE***
I also put on new tires because the old ones were DEAD...same size and type as before (28x11.5 Hoosier QTP)
[Re: FlyFish]
#726561
07/19/10 10:06 AM
07/19/10 10:06 AM
Challenger 1
Cincinnati, Ohio
***UPDATE***
What was the density alitiude on the before and after runs?
[Re: Challenger 1]
#726562
07/19/10 11:04 AM
07/19/10 11:04 AM
Posts: 1,178 Indy
FlyFish
Indy
One of the guys near my pit said the DA was ~ 4000 feet (about 92° F). The previous run was the same temp, but I don't know what the DA was. What I do know is with the old intake the worst 60’ times ever were 1.56-1.57, on “normal” hot summer days it would run 1.53’s. Also, the MPH was close to normal…down just a little. Normal in the heat, ~96.0-96.5…with the Victor it ran 95.6-95.9.
I think with a bigger cam, this intake would be great, but apparently my cam is just a little too small….or if I was running ¼ mile it would probably be faster since I would be spending more time above 6000 RPM…just thinking out loud.
