My carpool partner has a 07 Ram with the 3.7 v6 /manual trans/6-speed , he's had a check engine light come on intermitantly for the EGR valve. Yesterday on the way to work it flashed and we stopped at a AutoZone to get the code and came up with p0205 and p0305, both #5 cyl, one was a misfire the other was injector problem? Obviously they are both related to the injector ! Just thought I would post it to see if anybody has any solutions! We put some injector cleaner in the tank and he checked the plug but that looked fine! It had a noticable mis at idle ,but that seems to come and go, Any Ideas or sugestions? Thanks in advance!
