I put it on my 440 with non ac brackets and pullys
had to flip it over and use the single ear/lug as a pivot point and shim it out with a tube spacer
this moves the power stud out away from the head and just leaves enuff room for the field wires to bolt up
only has about 1/4" clearance by the core plug on the end of the head
I just used a long thru both on the ears/lugs for the adjuster side
I had to make the lower swing arm a couple inches longer also
maybe a low mount brackets will work for you
so far I have not seen it on a/c cars/trucks
seems I used the power steer belt when I removed it for manual and went to the mini alt at the same time
took some fiddling till I figured to flip it over and mount it
its in the sig pic,if some close ups might help give you an idea let me know I will snap some
