Re: 68 Charger Electrical Gremlin
[Re: 440_ci]
#726129
06/16/10 11:01 PM
06/16/10 11:01 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Double check your ground wire from the motor to the body. Also. Loose connection at the back of ammeter guage?? Or guage itself is taking a dump??. When it shorts out completely,yer on foot with nooo power to anything. Remember that the ignition is powered through the - side of the guage. Here's a simple test. Run a jumper wire--with a fusible link- from the BATT stud from the back of the alternator to the BATT stud at the starter relay. Car should purr like a kitten and ammeter guage should read normal. This takes a huge load off the ammeter guage.It may not be 100% accurate but will still flicker with the signals,etc. Should your alternator short out again,the fusible link will pop instead of frying your car. Hope this helps. Been there...did the fire extinguisher thing.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: 440_ci]
#726130
06/17/10 07:34 AM
06/17/10 07:34 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Sounds like ammeter or ammeter wiring going south on you here too.
