Re: best way to bleed hydraulic throw out bearing
[Re: dirt]
#726070
06/16/10 07:57 PM
06/16/10 07:57 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Sounds like it is time to invest in a vacuum or a pressure bleeder.
'course a pressure bleeder is preferred but the vacuum is easier to work with
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
