Please explain NPT fittings?? #72539
06/12/08 09:32 PM
06/12/08 09:32 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I need to add NPT fittings with 5/16" nipples to the Carter street fuel pump I just bought. How do I know if I need 1/4" NPT or 1/8" NPT? The pics on Jeggs look the same. Is the difference the diameter or the pitch/coarseness of the threads? I don't even know what NPT stands for, but I do know it is a non gasketed interference fit.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Please explain NPT fittings?? [Re: GO_Fish] #72540
06/12/08 09:33 PM
06/12/08 09:33 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
national pipe thread, summit says you need a 1/4" npt. I'd recommend using teflon tape on the threads as well.
http://store.summitracing.com/partdetail...mp;autoview=sku
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Please explain NPT fittings?? [Re: GO_Fish] #72541
06/12/08 09:33 PM
06/12/08 09:33 PM
Kirkland, Washington
Pacnorthcuda Offline
NPT...National Pipe Thread. They are tapered, get larger as you go....self tighting. Thats their job.
Re: Please explain NPT fittings?? [Re: GO_Fish] #72542
06/12/08 09:59 PM
06/12/08 09:59 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Thanks guys! I bought my pump from Mancini, and their site does not give all the info that the Summit site does. The directions that came with the pump specifically say not to use teflon tape, it will break the fitting. I guess it is too slick and results in over torque? Anywho, I can now order my 1/4 npt fittings with 5/16" barb.
Re: Please explain NPT fittings?? [Re: GO_Fish] #72543
06/12/08 10:16 PM
06/12/08 10:16 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
They are a nice pump, I just put one in my dart. Do not use teflon tape. I think the threads are NPTF on the pump side. Tape will crack the housing. You can get the fittings pretty much any hardware store if you want brass. If you want cool blue anodized PM me and I'll send you some.
Re: Please explain NPT fittings?? [Re: Dart 340] #72544
06/12/08 10:25 PM
06/12/08 10:25 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Interesting, i got my pump used when i ran the carter pump. So nothing told me to not use teflon tape, it ran just fine for a daily driven year with the teflon tape. I still have the 'good used' carter pump in my boxes. I run teflon tape on the NPT fittings at my fuel pressure regulator, holley blue pump and fuel filter. No issues in 3 years there.
2020 RAM 1500
Re: Please explain NPT fittings?? [Re: GoodysGotaCuda] #72545
06/12/08 10:45 PM
06/12/08 10:45 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Mine said not to use it. I think the reason it that they are nptf (fuel) threads. One is straight and one is tapered so they self seal. If it's working well, dont mess with it.
Re: Please explain NPT fittings?? [Re: GoodysGotaCuda] #72546
06/12/08 10:48 PM
06/12/08 10:48 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I went through this when I was very young and it is confusing.
Here is the same as below but the website which is easier to figure out.
Its two different worlds...I hope this helps.
http://www.plumbingstore.com/pipethreadsizing.html
Definition of pipe thread acronyms
NPT National Pipe Thread
FPT Female Pipe Thread
MPT Male Pipe Thread
PTF SAE short tape pipe thread
NPTF American National taper pipe thread for dryseal pressure-tight joints
NPSM American National straight pipe thread for mechanical joints
NPSI American National straight intermediate pipe thread
Male threads: Measure the outside diameter of the large portion of the thread at "A"; Find figure nearest this dimension in column 1 or 2 of chart. The dimension in column 3 will be your nominal pipe thread size.
Female Threads: Measure top diameter of thread at "B"; Find figure nearest this dimension in column 1 or 2 of chart. The dimension in column 3 will be your nominal pipe thread size.
Column 1 Column 2 Column 3 Column 4 Column 5
OD Fraction Inch (for quick reference only) Actual (decimal) Inch. Pipe Thread Size Normal engagement for tight joint (dimension "C") Threads per Inch
5/16 0.3125 1/16 0.2611 27
13/32 0.405 1/8 0.2639 27
35/64 0.540 1/4 0.4018 18
43/64 0.675 3/8 0.4078 18
27/32 0.840 1/2 0.5337 14
1-3/64 1.050 3/4 0.5457 14
1-5/16 1.315 1 0.6828 11-1/2
1-21/32 1.660 1-1/4 0.7068 11-1/2
1-29/32 1.900 1-1/2 0.7235 11-1/2
2-3/8 2.375 2 0.7565 11-1/2
2-7/8 2.875 2-1/2 1.1375 8
3-1/2 3.5 3 1.2000 8
4 4.0 3-1/2 1.2500 8
4-1/2 4.5 4 1.3000 8
Two common pipe thread sizes exist, the tapered National Pipe Thread (NPT) and the straight National Standard Free-Fitting Straight Mechanical Pipe Thread (NPSM). The tapered threads are for joining and sealing, the straight threads are only for joining. The Dry-seal thread (NPTF) allows for joining without sealants. Three less common threads exist, the Garden Hose Thread (GHT), Fire Hose Coupling (NST) and British Standard Taper Pipe Thread (BSPT). The NPT and NPTF threads are interchangeable with sealants such as PTFE tape. None of the other thread standards are interchangeable. Female NPT threads can be designated as "FPT" and male NPT threads can be designated as "MPT."
Pipe sizes do not refer to any physical dimensions. The outside diameter of each pipe or fitting must be measured and compared to the table for size identification. For example, a 3/4" NPT pipe thread has an outside diameter of 1.050 inches. Each thread size has a defined number of threads per inch (TPI). The 3/4" NPT pipe thread has 14 threads per inch. Both the TPI and OD of the thread are required for positive identification of thread size because several sizes have the same TPI.
Re: Please explain NPT fittings?? [Re: Dart 340] #72547
06/12/08 10:50 PM
06/12/08 10:50 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I would guess that the Teflon tape "lubricates" the threads to the point that the fitting can be easily overtorqued and crack the female fitting (housing).
Re: Please explain NPT fittings?? [Re: quick77rt ] #72548
06/12/08 11:27 PM
06/12/08 11:27 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
thats absolutely awesome! you spent way more time explaining this and I would have. Two thumbs up.
Re: Please explain NPT fittings?? [Re: 6PakBee] #72549
06/13/08 12:01 AM
06/13/08 12:01 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
I doubt that overtorquing or cracking is the issue with Teflon. I would suspect that it is MUCH more likely that ordinary teflon tends to break down when exposed to petroleum products. Anytime I have to deal with a fitting that's going to have any kind of petroleum product, liquid or vapor, I need to use a thread sealant (liquid or tape) that is rated accordingly. Nothing worse than a fire because a leak generated from sealant breaking down...or winding up with the junk in your carb or injectors...
2 Demons...no, not my kids!
Re: Please explain NPT fittings?? [Re: 4speeds4me] #72550
06/13/08 07:22 AM
06/13/08 07:22 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I assumed (there's that word again!) that we were talking about the applicable Teflon sealing tape, not something you'd pick up at Home Depot. If you do a web search there are Teflon tapes formulated for fuel usage. Is it still a good idea? I don't know. I'm not a personal fan of tape. The tape gives you a false indication of how tight the fitting is. I've personally cracked fittings and some of my friends have, primarily in castings, from overtorquing the fitting. I like something like Loctite 567, a gasoline rated anaerobic sealant. But whatever floats your boat.
Re: Please explain NPT fittings?? [Re: 6PakBee] #72551
06/13/08 08:38 AM
06/13/08 08:38 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm a fuel dealer, when I get new fuel nozzles in the box the directions say Not to use teflon tape. The tape acts like a wick and causes the fitting to weep. Ever notice how the tape turns yellow after some use? Plus as we all know, if it is applied wrong it can get in places you don't want it.
Re: Please explain NPT fittings?? [Re: Challenger 1] #72552
06/13/08 11:18 AM
06/13/08 11:18 AM
SW Minnesota
Dennis_K Offline
Dennis_K  Offline
SW Minnesota
I'm sure you will find NPT fittings with hose barbs at your local hardware store, so you don't have to order them from anywhere, and you can bring your fuel pump into the store and make sure they fit before you buy them.
Re: Please explain NPT fittings?? [Re: Dennis_K] #72553
06/13/08 04:56 PM
06/13/08 04:56 PM
dogdays Offline
dogdays  Offline
Nice brass fittings at Ace Hardware.
R.
I have used teflon tape with success. Try to keep the bits of tape out of the inside of the fitting, they have been known to plug small openings. I have also used Fel-Pro TIGHT which is a teflon-bearing liquid sealant. It's not that complicated!
Re: Please explain NPT fittings?? [Re: Pacnorthcuda] #72554
06/13/08 08:56 PM
06/13/08 08:56 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
self tighting.
Well this got me curious 'cuz I'd always tightened 'em myself so I laid a fittin' on the bench next to a pump I had lyin' aroun' and went in an' had my supper an' when I went back out to the shop they wuz in the same place I left 'em. So I got t' thinkin' maybe I got the self-sealing kind an' not the self tightenin' kind !!!
Re: Please explain NPT fittings?? [Re: Stanton] #72555
06/14/08 12:00 AM
06/14/08 12:00 AM
Westphalia, Meeeeeshigan
MIRADAMANia Offline
MIRADAMANia  Offline
Re: Please explain NPT fittings?? [Re: MIRADAMANia] #72556
06/14/08 10:39 AM
06/14/08 10:39 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I always get a little motor oil on my finger tip and smear some on the threads. Just enough to keep the threads from galling.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
