Filler tube #725483
06/15/10 10:34 PM
06/15/10 10:34 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
What can be done to restore a 69 charger fuel filler tube?
Re: Filler tube [Re: NITROUSN] #725484
06/16/10 08:22 AM
06/16/10 08:22 AM
Aside from painting them, not much. They were a lead-tin type of plating which no one seems to do anymore. I have a spare if you are looking to buy one.
Re: Filler tube [Re: NITROUSN] #725485
06/16/10 09:02 AM
06/16/10 09:02 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Rub it down with fine steel wull if it's not too bad. That's about it. Painting it won't look right.
Re: Filler tube [Re: burdar] #725486
06/16/10 09:18 AM
06/16/10 09:18 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
If it's rusty and OK inside, what about using eastwoods "Tank Tone" paint on it?
Re: Filler tube [Re: ] #725487
06/16/10 09:41 PM
06/16/10 09:41 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
I had mine powder coated and it just does not seem right. I will post a pic. PM me on your spare one as I am interested.
Re: Filler tube [Re: NITROUSN] #725488
06/16/10 10:27 PM
06/16/10 10:27 PM
Ive tried the tank tone before I ended up getting a third good one. The one that I had painted with Tank Tone from Eastwood did not have anywhere close to the original appearance. The original one in my car I replaced due to some small dents that were on the underside of the tube that I could not live with. I found a really nice mint one that had some rust on it that I was able to clean off but left dark spots but that was not too bad for me since the lead-tin plating had light and dark areas.
NitrousN, you have a PM.
Re: Filler tube [Re: ] #725489
06/17/10 08:19 AM
06/17/10 08:19 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
A friend did his in HAMMERTONE, and I think it would be the closet to the lead-tin plating that your going to get in a paint.
Re: Filler tube [Re: rayztoy] #725490
06/17/10 08:32 AM
06/17/10 08:32 AM
Ont, Canada
gygeneral Online content
gygeneral  Online Content
Ont, Canada
I had mine plated in zinc
Re: Filler tube [Re: ] #725491
06/17/10 08:46 AM
06/17/10 08:46 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I just did one yesterday in eastwoods tank tone and I'm not impressed.It just looks like dull silver paint.
I'm gonna try the hammertone finish today and go from there.
Re: Filler tube [Re: gtx6970] #725492
06/17/10 09:49 AM
06/17/10 09:49 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That zinc one looks really good. I never thought of that. I think that is a really good alternative. It doesn't look stock but it does look a lot nicer than paint.
Re: Filler tube [Re: gtx6970] #725493
06/17/10 11:03 AM
06/17/10 11:03 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Bill,
If you use the Hammertone, you have to play with it by varying the spray pattern distance and angles to get it looking NOT like a paint, which is uniform in appearance.
Ray
Re: Filler tube [Re: burdar] #725494
06/17/10 11:09 AM
06/17/10 11:09 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I went the zinc plating route as well. Most of mine is hidden (68 RR) unlike yours. That galvanized finish is tough to duplicate.
Re: Filler tube [Re: 68jim] #725495
06/19/10 11:29 AM
06/19/10 11:29 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Well,'
I did the hammetone paint this week. and I have to admit , I like the look. So much I did the license plate support as well.
Keeping in mind, Obviously it's no where near OE correct. But this car will never be judged on a national stage. It'll be driven WAY to much to be trying for $3 trophies.
Re: Filler tube [Re: 68jim] #725496
06/19/10 11:55 AM
06/19/10 11:55 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
"That galvanized finish is tough to duplicate."
It's actually lead dipped.
I have been looking for years for a shop to do this.
All say it is a health hazard procedure.
Jules
Re: Filler tube [Re: JulesdaWiperman] #725497
06/19/10 05:43 PM
06/19/10 05:43 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
Are there different types of lead dip??. I may have a shop that will do it, but I would like to know for sure I am asking for the right type of finish that will duplicate the factory.
Dan
Re: Filler tube [Re: mopar4ya] #725498
06/19/10 06:37 PM
06/19/10 06:37 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Tank tone from Eastwood doesn't look good on anything! You can have my extra cans. I've used it on my new gas tank and it looks just like someone sprayed dull silver on the gas tank. I ended up using a satin clearcoat paint.
Re: Filler tube [Re: mopar4ya] #725499
06/20/10 08:29 AM
06/20/10 08:29 AM
super gas
super gas
mopar4ya
I really don't know.
I do know that you can rub away or melt away the lead on these filler tubes quite easily.
I don't know the chemical make up of it.
Jules
Re: Filler tube [Re: JulesdaWiperman] #725500
06/20/10 01:32 PM
06/20/10 01:32 PM
MO
cdp Offline
cdp  Offline
MO
Somewhere on the A12 board, there was a member who had restored their filler neck and it looked fantastic.
I couldn't find the thread, but its maybe 18 months old at most.
If I recall, they used some eastwood tinning/lead on the outside and then painted some glyptol red/black on the ends. This was what they had found on a few survivor cars.
FOUND IT!
http://a12mopar.com/yabb/YaBB.pl?num=1238949100/3#3
Re: Filler tube [Re: cdp] #725501
06/21/10 11:04 AM
06/21/10 11:04 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Hammertone finish - in a spray bomb
1970 cuda filler tube
Re: Filler tube [Re: gtx6970] #725502
06/21/10 11:05 AM
06/21/10 11:05 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
closeup
