Re: TTI exhaust - 72 RR. X-pipe need shortening?
[Re: 72roadrunnergtx]
#724952
06/15/10 09:35 PM
06/15/10 09:35 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Thanks for the replies. I will double-check the number stampings when I get home. Also mock up the header-to-x-pipe sections by themselves, just to see how that fits. Right now, the mufflers sit pretty nicely in the floor cavities with the tailpipes' peaks right over the top of the axle. But the tailpipes are bottomed in the muffler outlets - no more rear movement possible with the muffs.
One more Q: Right now the rear is hanging on the shocks (KYBs, if it matters), as the car is on jackstands. As far as proximity to the driveline, how close should/could the pipes be to the driveline?
Thanks again, Marq
#724953
06/19/10 02:46 AM
06/19/10 02:46 AM
MoparMarq
Vancouver, WA
Marq, I had to take an inch or two off the rear of the x-pipe to get the muffler hangers to correctly line up. Sounds like you are running the same system as I am. Also needed to shorten up to forward end of the tail pipes to clear the axle. I just assumed the pipes were designed to accommodate slightly shorter mufflers as well as the DST’s.
After mocking it up, I noticed that I have a TON of clearance between the turn pipes (between collectors and x-pipe) and the trans x-member. Looking at your pic, I notice it has quite the clearance also. I just wanted to make sure that this is the way it's supposed to be, not some weird situation. Looks like they could have been tucked up tighter. But maybe that's what they look like with the Tremec trans in there. The trans tailshaft housing is durn near touching the trans x-member (1/4" clearance maybe), so I can't get it much higher. Is this pretty typical?
On another note, I did shorten the outlets of the x-pipe by 1 inch. Fits together much better, but still not quite perfect. I may have to shorten the inlets to the tailpipes by an inch or maybe a 1/2 inch.
