Anyone have a '71-'72 Dodge Parts Book? #724942
06/15/10 12:02 PM
06/15/10 12:02 PM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
I need lower door hinge "S" springs for my '72 Charger. I have found a vendor that says he has N.O.S. part #3586386 and it is for a '71 and up B body lower door hinge spring. The problem is, it seems they used 2 different springs, 1 coil spring and 1 "S" spring. The vendor will not pull the part to look at it or take pictures of it until he receives my money. So if anyone has a parts book and could look up the lower door hinge spring and see if that number matches up I would be in your debt.
Thanks in advance,
Reid.
Re: Anyone have a '71-'72 Dodge Parts Book? [Re: Moparguy383] #724943
06/15/10 12:46 PM
06/15/10 12:46 PM
Mass
charge70 Offline
charge70  Offline
Mass
Reid,this part# is in the 71 and 72 parts book with a description as "Spring,door lower hinge.Front door,door half." There is no picture for this part# and there is no breakdown pic for the hinge.Hope this helps. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Anyone have a '71-'72 Dodge Parts Book? [Re: Moparguy383] #724944
06/15/10 03:30 PM
06/15/10 03:30 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
SPRING, Door Lwr. Hge.
Frt. Door, Door Half 3586386
Use After Feb 10, 1972 3696446
Re: Anyone have a '71-'72 Dodge Parts Book? [Re: Snoopy] #724945
06/15/10 05:43 PM
06/15/10 05:43 PM
Cumberland, MD
Cumberland, MD
Thanks for the help!
Reid.
