hooker 5903 header fitment #724169
06/14/10 02:08 PM
06/14/10 02:08 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Anyone run these in a 68-70 b body with column shift? Headers are out being coated and want to have car ready for carlisle. Need to know if I'll have to buy a floor shifter or not in my 70 satellite...
Re: hooker 5903 header fitment [Re: kbcuda] #724170
06/14/10 02:12 PM
06/14/10 02:12 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If these are the 1 7/8 Hooker headers, they do clear floor shift, but the set I had hit the left torsion bar. I had to attach a piece of rubber to the t bar to lessen the vibration and to minimize heat transfer.
These headers are NOT easy to install. Take a pill before you begin!
Re: hooker 5903 header fitment [Re: Kern Dog] #724171
06/14/10 02:31 PM
06/14/10 02:31 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I had an aftermarket cable operated floor shifter with them in my car. One thing I didn't like was the one collector went straight towards the crossmember, not to the raised area for the exhaust, which meant more work to get the exhaust to fit. They didn't take much dinging to fit. And yes they are a major pain to install!
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: hooker 5903 header fitment [Re: Silver70] #724172
06/14/10 03:38 PM
06/14/10 03:38 PM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
It's a mopar headers are a pain. That said the shift linkage will all clear no need to go to the floor and as hard to install as they are being 1 7/8 tubes will make life much easier.Small price to pay for a B-body car....
I have 2" hookers on my runner and still using the stock column shifter with a reverse manual shift valvebody. Have fun
Re: hooker 5903 header fitment [Re: a4runer] #724173
06/14/10 06:53 PM
06/14/10 06:53 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The "straight back" collector issue with most header designs really annoys me. TTI is the only manufacturer that I know of that directs the collector to the raised areas of the trans crossmember. Hedman, Doug Thorley and Hooker require a zig zag to get around the crossmember, and each bend increases backpressure.
Re: hooker 5903 header fitment [Re: a4runer] #724174
06/14/10 07:12 PM
06/14/10 07:12 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I ran a 2" set of hedman headers on my 70 runner and they had slip fit tubes... easiest headers I ever installed in my life!
Re: hooker 5903 header fitment [Re: Silver70] #724175
06/14/10 07:15 PM
06/14/10 07:15 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
The Hooker 5209 2" headers also have one pipe on each side that is slip fit. The drivers side "Fits" between the T bar and the frame rail...IF you move the brake combo valve and bash the pipe in. What brainiac approved that design?
Re: hooker 5903 header fitment [Re: Kern Dog] #724176
06/14/10 09:24 PM
06/14/10 09:24 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I always wondered where they came up with the designs. Do they even test fit the things? Or is there some other reason most fit so crappy? TTi's were the only really good headers I have ever installed... although the mini starter was a very very tight fit.
Re: hooker 5903 header fitment [Re: Silver70] #724177
06/15/10 09:42 PM
06/15/10 09:42 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
I've installed these hooker comps 1 7/8 in two other b-bodies without much issue. One barely tapped the torsion bar with the lumpy idle. I disconnected the exhaust and just pulled the header away from the bar by hand and it was enough to keep it from jingling... Both cars were floor shift so I wanted to make sure I didn't need to change the column shift with these...
Re: hooker 5903 header fitment [Re: kbcuda] #724178
06/15/10 10:34 PM
06/15/10 10:34 PM
NC
Sixt8Chrgr Offline
Sixt8Chrgr  Offline
NC
so to put these headers 1 7/8" on a 68 Charger floor shift auto with a 383 is a royal pita? Will I or the shop have to "fabricate" parts to make these fit? I just hate doing that...man and the price for the TTI's is brutal.
Re: hooker 5903 header fitment [Re: Sixt8Chrgr] #724179
06/16/10 02:02 AM
06/16/10 02:02 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
For ME, knowledge is power. My first Mopar header install was the 5903 pipes in my 440 Charger. I didn't know about the various obstacles with these cars. I was used to Chevrolet cars. Front steering gear and coil springs leave ALL SORTS of room to work.
The TTI headers come with INSTRUCTIONS! Hey other guys, ARE YOU READING this???
When you begin the header install, it helps to go into it KNOWING that it isn't an easy job. My problem is that I am an optimist and get annoyed easily... strange personality mix to live with being a Mopar guy.
REMOVE the center link. REMOVE the starter. If you have access to an engine hoist, use it instead of a floor jack under the oil pan. When you do this job with open eyes, it isn't that bad.
Re: hooker 5903 header fitment [Re: Kern Dog] #724180
06/16/10 07:42 AM
06/16/10 07:42 AM
NC
Sixt8Chrgr Offline
Sixt8Chrgr  Offline
NC
ok thanks
Re: hooker 5903 header fitment [Re: Sixt8Chrgr] #724181
07/05/10 12:14 AM
07/05/10 12:14 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
?*&&^^&%$$#$#%*&@#%$&6!!!!!!! I knew I was gonna jinx myself. I installed the headers a few days ago and what a [Edited by Moparts - Family Friendly Site - Keep it clean]!!! they slid in pretty well but the passenger side header was the worst. The front tube comes back at such an angle that you couldn't slide the bolt over enough in the slot to line up with the head. I had the small 3/8" head bolts. I ended up grinding the head down half way and cutting down about a 1/4" off the threads after I took a rounded head spike on the air hammer to the tube. After being able to get the bolt in and tightening up the header two pipes were pressing up on the torsion bar. Hammered the hell out of the two pipes to make maybe 1/4" clearance. Oh did I mention i paid $240.00 bucks to have them caoted plus the $80 bucks to ship them to and fro??? After all that both headers have absolutely miniscule clearance between the length of the collectors and the torsion bars touching in some places. So I have a lovely rapppity rap rap at idle. What pieces of crap. Hooker has been making these for over 30 years! You would think they'd take some time and re-design these things. How hard can it be? I've got tons of room between the headers and the block and the trans....So enough of my rant. Do you think I should exchange for another set? Maybe i got bad pair? I bought them through Advance so I can either return them or the manager said if i want to exchange them for the coated ones he'd pay for 1/2 the difference between the non- coated and the coated. Are there any other alternatives that fit better like the heddman elites or something else? I don't have the $800 for TTI's So please don't go there...
Re: hooker 5903 header fitment [Re: kbcuda] #724182
07/05/10 12:18 AM
07/05/10 12:18 AM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Hooker will never get another red cent out of me. Bunch of lying no good SOBs if you ask me.
Re: hooker 5903 header fitment [Re: kbcuda] #724183
07/05/10 12:21 AM
07/05/10 12:21 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Sorry dude but ditto for me. I banged the hell out of the driver side had little or no clearance on the p/s sector then just like you said got no clearance on either t-bar. I tookem back off cutem up and made new header to clear whatever I wanted. Unfortunately what I made is 2-1 tubes but all you need out of the way to take in and out is the starter. HOOKER look great in the box but never seem to fit without just pounding them to pulp.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: hooker 5903 header fitment [Re: kilroy] #724184
07/05/10 12:35 AM
07/05/10 12:35 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Think they'll be at carlisle? Doesn't Holley own them now?
Re: hooker 5903 header fitment [Re: kbcuda] #724185
07/05/10 04:22 AM
07/05/10 04:22 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You asked in the tread, then you bought them or already had them and wanted to know? I told my experience with them... never again
Re: hooker 5903 header fitment [Re: Silver70] #724186
07/05/10 10:43 AM
07/05/10 10:43 AM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Already had bought them.... Like i said I've used them twice before a few years back and didn't remember that much of an issue. Is there quality control that bad? Could I have just gotten a bad set? Should I exchange them and try another?
Re: hooker 5903 header fitment [Re: kbcuda] #724187
07/05/10 12:36 PM
07/05/10 12:36 PM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
The quality went down once they were fabed in MEXICO .
Re: hooker 5903 header fitment [Re: RTshaker] #724188
07/05/10 05:59 PM
07/05/10 05:59 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Hmmmm....I dont know if my Hooker headers are 5903 but I ordered them from Summitt specifically for my 70 Charger RT.
They are Hooker Comp 1 7/8 ceramic coat and they were very easy to install and fit very good with very good clearance. My car is a 4speed,Lakewood Bell,mini starter,RB block,Stealth heads with large 1.06 torsion bars.
I dont think I got the only set that ever fit cause lots of guys have had success with them.
