Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: gtx69]
#723558
06/24/10 12:37 PM
06/24/10 12:37 PM
Posts: 75,087 A Banana Republic near you.
JohnRR
Which way is better to hook up the power.Alternator'battery or at the starter relay?What guage wire are you using 10 guage?
10 gauge is for 30 amps , that thing pulls 60 to start , I think you are looking at a 4 gauge CABLE ...
[Re: JohnRR]
#723559
06/24/10 02:17 PM
06/24/10 02:17 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
I would assume you wouldn't need a heavier gauge than MB supplied to it from the factory, and you could look at the plug and tell it's not 4g.
[Re: gtx69]
#723561
06/24/10 04:07 PM
06/24/10 04:07 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The fan flashed to 50 amps just long enough to see it on a digital meter then it backed down. They run at 39 amps.
I ran from the alternator. You can do that, the battery, or the starter relay. Whatever is easiest. They are all major power centers.
The wire from the factory is 12 gauge with really thick insulation. Since I only had to run 3 feet of wire, I used some 10 gauge that I had on hand. It's thicker than the 12 gauge the factory uses to run 5 feet from the power distribution block.
If you have to run from a battery out back, I'd step up a size but if you're keeping the run fairly short you should be okay. 4 gauge cable isn't necessary. The 130+ amp alternators don't run that size cable back to the battery. Perhaps you're thinking 120 VAC?
Have you fired up that fan yet as a bench test? The first time you do, you'll wonder when it's going to start spinning. When it begins to spin you'll wonder if it'll ever stop accelerating. They really do move stupid amounts of air.
[Re: HealthServices]
#723564
06/24/10 04:18 PM
06/24/10 04:18 PM
feets
Senior Management
Senior Management
Irving, TX
Pretty close! I just sent a friend a message asking if I could borrow his anemometer to check the air velocity coming out of the fan.
[Re: feets]
#723565
06/24/10 06:57 PM
06/24/10 06:57 PM
Posts: 2,578 sweden
1Fast340
sweden
very intresting! think i may have a good look at one of these fans if i can fit it in my a-body. also i gues it would be a good idea to upgrade from the small stock alternator while being at it 40amps running is alot of power but well worth it if it cools the motor right thanks for the upgrade advice
[Re: 1Fast340]
#723566
06/24/10 08:56 PM
06/24/10 08:56 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Problem is, without an appropriate test machine, a standard DVMM can't measure the in-rush current of the fan as it kicks on. Although with it ramping up like I see in the video, it won't be nearly as high as just slamming it. Any more information about differential voltage to the trigger having an effect on fan speed. I'd place my order tonight if that were the case Planned on programming a controller myself to handle multiple output voltages based on temp.
[Re: Pat_Whalen]
#723567
06/24/10 10:50 PM
06/24/10 10:50 PM
feets
Senior Management
Senior Management
Irving, TX
I might be able to get a 5 volt sensor signal to the fan by unplugging my relay under the dash and jumping power from my EFI sensor output. It's a long shot. I do know that Andrewh's Mercedes has a multi-speed fan and it's the same style setup as these. It usually runs on a low speed until the A/C kicks in then it steps up.
I've got to mess with the hot rod this weekend because I lost my dash, tail, and brake lights. If I get the chance I'll try the fan with a 5 volt signal.
[Re: gtx69]
#723569
06/24/10 11:37 PM
06/24/10 11:37 PM
feets
Senior Management
Senior Management
Irving, TX
No. The second small wire is a feedback for the engine computer according to my shop foremen. They've been working on Mercedes for 20+ years so I'm inclined to believe them. I tried powering and grounding the second wire while the fan was running and while it was stopped. I got no response.
[Re: feets]
#723573
06/25/10 01:51 PM
06/25/10 01:51 PM
Posts: 4,978 VA
DAMOPARS
VA
Do we have any road tests yet? What was your temps before and after? What set up were you using before this fan. Nice post feets
[Re: DAMOPARS]
#723574
06/25/10 02:27 PM
06/25/10 02:27 PM
feets
Senior Management
Senior Management
Irving, TX
We do have driving results with Andrewh's 65 Coronet with a 5.9 Magnum. The fan only runs for a couple minutes. In that time it pulls the temp down low enough to shut itself off. He has an aluminum radiator and I believe a 180 degree thermostat. His old system consisted of a '90 Nissan Maxima fan and brass radiator. It was the same system I had in the hot rod. I have heat soaked the TT440 in the hot rod to 230 degrees (stuck thermostat) and the fan pulled the temp down to 200 in a few minutes of idling. It will run down the road between the on and off temps I have set on the fan. It's set to turn on at 195 and off at 175. The water thermostat is a 180 degree unit. When idling in the driveway the fan can pull the engine temperature lower than the thermostat is set to open. It's pretty impressive in my book when you can cool the engine low enough to close the thermostat and keep dropping the temperature of the water pump housing with the engine running. That's on a 100 degree Texas summer day. As soon as I figure out why I don't have any tail, brake, or dash lights I'll get it back on the road.
[Re: feets]
#723575
06/25/10 03:23 PM
06/25/10 03:23 PM
Andrewh
it has a stock 5.9 thermostat, so it is 190 or 195, can't remember which.
The computer is set to turn the fan on at 210 and shut it off at 195. I regularly see the temps go down to 187 when the fan shuts off.
Only when the a/c was running have I ever seen the fans run contiuously at idle. I guess it just gave off that much more heat that it never got to the 195 shut off. But I didn't have the computer hooked up at that time, so I can't tell you the exact temp. I don't have the new trinary switch hooked up yet, so it had nothing to do with the a/c being on other than temp.
I think it was about 85 in the garage at that time.
I only had one instance where it ran a bit warmer than normal. On the way to feets house that day. Doing around 80 ish on the way there, it ran just a little hotter than normal, but on the way home I didn't see anything different. It was about 20 degrees hotter that evening vs the morning I drove over. All I can figure is the fan came on before I hit the freeway and didn't allow enough air to pass to get to the shut off temp. But I didn't over heat, so no big deal.
I do run a dual pass cross flow, so I am not sure how it will cool with a normal rad.
I can tell computer temps when I hook up a laptop, but only have the old gauge to go by when driving. normally it stands straight up and down during normal driving. Just slightly over on the hot side when the fan comes on, and slightly to the cold side when the fan shuts off. It ran at the fan on place on the way, and it ran and the fan shut off temp on the way home.
I normally tool around town, so stop and go driving, and never had that issue.
[Re: Andrewh]
#723576
06/25/10 03:36 PM
06/25/10 03:36 PM
feets
Senior Management
Senior Management
Irving, TX
For the record, Andrewh lives 25 miles or so from my place and it's all freeway driving. The day of the Chrysler PDC show it was in the upper 90s outside. When he pulled into the shop at work his fan turned off in just a minute or so. My hot rod with the dual Maxima fans was running around 210 with both of them turned on.
