72 440 HEADS OR 1976 HEADS #723184
06/13/10 05:47 PM
06/13/10 05:47 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
putting a 440 in a 74 charger have 2 sets of heads 1972 and 1976 ..1976 has hardened valves the 72 were rebuilt years ago still in bag not sure if has hardened valves .what is the valve size or cc size ?? pretty much a stock rebuild with comp 484 cam auto trany 2400 stall 355 gears..
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 72 440 HEADS OR 1976 HEADS [Re: sparcy] #723185
06/13/10 05:56 PM
06/13/10 05:56 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Need the head casting #s. You can measure the valves easily.
Re: 72 440 HEADS OR 1976 HEADS [Re: sparcy] #723186
06/13/10 09:34 PM
06/13/10 09:34 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
If the 72 heads have been rebuit and the 76 haven't, i'd use the 72s. the 72 is probably a 346. I believe some of those had hardened seats. The 76s(452 )will for sure.Heads from 72 to 78 are all the same performance wise. I believe the need for hardened seats has been exaggerated. Seems like GM had a much bigger problem with valve recession than Chrysler did.
