launch rpm with cal tracs #723108
06/13/10 04:43 PM
06/13/10 04:43 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
68 dart with 440,foot braking launching at 2500 hooks than spins 4 to 5 feet out.Changed pre-load, shock settings,tire pressure to no change
Re: launch rpm with cal tracs [Re: dart443] #723109
06/13/10 04:54 PM
06/13/10 04:54 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
Weird because i'm launching off the foot brake at 3200 on a 29.5 x 10.5 slick, shocks set on 5, 1/4 turn preload, and on 200 spray and no spin at all.
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: launch rpm with cal tracs [Re: dart443] #723110
06/13/10 06:48 PM
06/13/10 06:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The "hook then spin" problem w/ my car went away when I reset my front suspection for 5"+ of extension from the static ride height, as per Calvert instructions were when I explained what the problem was. Hasn't done it once since.
Re: launch rpm with cal tracs [Re: BradH] #723111
06/13/10 08:56 PM
06/13/10 08:56 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
captain,I have 5" of front travel with calvert front shocks
Re: launch rpm with cal tracs [Re: dart443] #723112
06/13/10 09:09 PM
06/13/10 09:09 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
What rear spring and shock combo. sounds like hitting tire real hard and then unloading. What hole is the bar in?
JAKES AUTOMOTIVE
Re: launch rpm with cal tracs [Re: JAKE68] #723113
06/13/10 09:32 PM
06/13/10 09:32 PM
ontario canada
dart443 Offline OP
dart443  Offline OP
ontario canada
Jake,rancho shocks set at 5,stock 6cyl leafs,bar in upper hole.
Re: launch rpm with cal tracs [Re: dart443] #723114
06/13/10 11:29 PM
06/13/10 11:29 PM
BradH Offline
BradH  Offline
Try the lower hole and add 2 clicks more rebound damping to see if that keeps the "hop" under control better.
